@2021 LC200
If you don’t already know about it, bobistheoilguy.com is THE place to nerd out on lubricants.
Per internet search apparently Toyota 0W20 is 36.1 cSt at 40 C and 8.5 cSt at 100C
Per data above, PUP 5W30 is 56.3/10.3 cSt and QFS 5W30 is 66.65/11.6 cSt. Quite an increase actually in viscosity and during transition from startup to full operating temps.
Also looked up TGMO (Toyote Genuine Motor Oil) 5W30 which is 56.2 cSt/9.95 cSt at 40/100 C. PUP 5W30 is viscosity wise about identical, so probably will give that a go.
With the 3UR-FE originally designed for 5W30 it really puts the question around the suitability of 0W20 and the point made that bureaucrats at EPA are not engineers and/or interested in durability. Maybe I change my oil to 5W30 before 35k miles...![]()
I know, trying to discuss this in context with Land Cruiser 3UR-FE owners and experiences. Switching to 5W30.@2021 LC200
You have the 570 with the 3UR-FE? What viscosity oil are you running, beside this additive?Hi All, Interesting thread about chain rattle. I experienced a little of this not long after the Harrop 2650 install. After MUCH research, I started using an oil product called Engine Shield. Amazing stuff. Engine is soooo much quieter, revs more freely (not that it doesn't with the blower), and great oil pressure hot or cold. I also use a fuel additive with Premium 98 from the same company. Check out DXP Australia – Diesel and Petrol Fuel Additive for Improved Vehicle Performance - https://dxpaustralia.com.au
The vehicle has been serviced by Lexus from day 1, including after the Harrop 2650 install. I assume they used whatever the recommended factory spec oil up to the blower install, but we decided to go with the Castrol EDGE 0W-40 A3/B4 with Fluid TITANIUM (supplied by the dealer) after the install. The random chain noise started about 6 mths after the Harrop install at around 78,000 klms. It was then I started using the Engine Shield additive and haven't had any noise issues since.Hi AUS 570, for learning purposes; Did you run factory 0W20 and when you heard the noise switched to 0W40 + additive? Also at what approx. mileage (or km...) did you notice this issue?
