After bolting everything back together, I did a double and then triple check of all my connections and fasteners. I checked the torque on all my lug nuts (earlier, I had found one that was almost ready to fall off), topped-off air pressure and got under the truck and tightened all the belly pan bolts (thought it might be a good idea). I was shocked at how loose they were! Almost every single one was just barely beyond finger tight. Surprised I hadn't lost any. Finally, I filled the crankcase with Rotella T (15W-40).
The moment of truth. Grabbed the key and gave it a twist. Cranked for a couple of seconds and then backed-off. My battery is almost toast at this point so I was trying to be gentle. Cranked again and she fired up! Real cranky sounding, but running.
Didn't think to get video.
I let it idle for a few minutes to warm up. Idle was right about 650 RPM (at least from the gauge) but VERY rough.
Hopped in and gave her a go. When wound up a little (past 1300 or so RPMs) she seemed to run a little smoother, but when coming to a stop the truck would almost die. I thought it might be a vacuum issue so I re-checked all my lines. Everything looked good. I also re-checked my plugs/wires - they were good. Not sure what the problem was, I shut the motor down. For a little context, the truck ran pretty smoothly before my tear down. Not new Prius smooth, but 21 yr-old 3FE smooth.
I suspected that I might have jacked something up when removing/reinstalling my rocker assembly. That, or my dizzy was way off. I was super careful, but I guess you never know. Tapping out at this point as the thought of resetting the distributor and timing with never having done either before gave me angst.
Jason
