Steve (619TOY):
Need an update to this tread. Where are you now on this project?
... 2nd you cant realy use/dont need 14" travel shocks out back. ...
the point is to keep the 3 link cheap and simple so others would do it
i wish someone would let me cut up their truck
Do you guys that run 37s and up keep the fenders for looks? I mean, heck, by that point my fenders would be long gone. as soon as they start gettin in the way, just seems like extra hassle to me.
My 37's are relatively narrow, so tuck inside the fender wells. The contact is inside tire sidewall to fender well/frame, tubing/beating the fender wouldn't do much and moving the frame in would be lots of work just to gain a slightly shorter bump stop. If your talking about the flares, mine are not an issue, just took a little nip to the lower corner.
doh oh yea
then flip the arms and make a axle bracket for on top the tie rod clearance.
if you point the pinion right at the tcase you dont think you could leave the arms going below the tierod?
IMHO the cheapest way to do it with straight links, good steering, good link separation, etc would be to swap in a FJ60 or FJ62 axle. Add the Dave Gore widening sleeve to get the width right, nets you a bigger diff, locking hubs, cheap high steer, etc?![]()
yea and 60 axles are cheap.
note that my 42" iroks stuff great front and rear. just cut a bit and get the backspacing right. i used a 67 track d70 and a 69" dodge d60.
if you dont design in for stuffage on the 80 you will need way more lift to run the big meats
Well understood/proven, etc, but would need a locker, Longfields. The 80 axle has good value so when sold would still come out pretty cheap?
I watched your build in hardcore, good stuff, but more than I want on on my '80. When I get the itch for a more hardcore rig it will be in addition to the'80, ~ half the weight, no overhang, only enough body work to support a windshield, lights, be street legal and the rest tube.![]()
i dont know. im wheeling with minis right now. they cant hang. with a little better gearing and big meats the 80 is hardcore. i need to post up some vid....
PS - been meaning to say it for awhile, but that quote officially makes your sig the coolest here on mud IMO![]()
