- Joined
- Jan 6, 2012
- Threads
- 341
- Messages
- 10,925
Why not go with developing 32 spline custom shafts instead of 30 spline? Just curious.
Not sure what you mean. Early full float shafts? I didn't know their was a early and late 30 spline full float shaft.I'm sure RCV would entertain it... reality is FF shafts generally break at the side gear which is stuck at 30 unless you do some 100/200 reverse trickery which is doable using side gears from a 100 e-locker or ARB. We used to do 4.88's in 100's using an 80 carrier and 100 side gears, this before Nitro came out with 100/200R specific gears.
Early 30 spline FF shafts are ~35mm at the seal surface, 36mm for the later shafts. This might have an impact on how much shaft will fit thru the spindle without boring.
When I broke a Nitro rear shaft in Moab two years ago they told me the warranty had no horsepower or tire size limit. The stories sound different. Your rig is heavy and you wheel a lot so I’m still of the mind that you might as well go with tons or custom built axle assemblies.Slee will have them soon according to posting above and Im still waiting to hear back from CTM axles info@ctmracing.com
the Nitros in the rear were the problem splines are too long and they twist up easy. and actually nitro TOLD ME, their axles were not made for what I do.
The biggest reason to run 32 spline shafts is to run the newer style 9.5 gears with a significantly wider tooth face and thicker pinion shaft.
IF you are doing lockers and gears anyway and planning on HD shafts like these, using the newer gearset will give more strength for about same price. The same gears that Toyota uses behind 450 ft-lb twin turbo V8 diesel in heavy 200 series. (Those of you running V8s on 40s may want to go this route.)
If you already have gears and lockers, the these 300M 30 splines are the way to go!
This was my point two years ago when I broke one that was actually defective. I found out these shafts are made in Korea but supposedly “assembled in USA”. I got hate posts because I blamed lack of QC oversight in a factory on the other side of the planet.Holy crap this is extremely discouraging.
So if the 32 spline is 34.8mm then the spline tooth size they are using are probably the same between the 30 spline and 32 spline. Thus the bigger diamater of the 32 spline which is the case with most other axle shafts. According to the axle charts Ive looked at, if both axles are made from the same material, going from 30 spline to 32 spline would give about a 20 to 25% increase in strength. So if the stock 80 30 spline of oem material fails at lets guess an estimate 8,000 ftlbs of torque, the 32 spline should hold up to 9600ftlbs or more. Going to chromoly or 300m would increase even more. I know a few guys on pirate have gone 35 spline shafts with ARB lockers being used. Not sure if they machine the spindle.Absolutely... really the 90-97 is a later but still 35mm, 30 spline FF's started in MY 1976. Buy a 42312-60090 rear FF and it supercedes to 42312-60091 which was used in a 2000 era non-US 8x with the 36mm seal, same as the 98+ 105/7x stuff was getting too. They are visibly different seals as 1mm makes a big difference when dealing with an already incredibly thin seal. Likewise buy a new OEM Toyota rear FF for an 8x and you're likely getting a 36mm seal surface... not much room left through the spindle BUT we know the shaft can be at least 36mm whereas the 30 spline shaft is 1.31" (going by memory there) which is ~33.3mm. EDIT: confirmed 33mm/1.31" OD on the 30 spline
EDIT: the 32 spline shafts are 34.8mm OD (shaft, not seal surface), they use the 36mm ID seal so not a huge "step-up" for the seal surface. Assuming the spindle ID on an 8x would accommodate the 34.8mm shaft OD, it's totally doable with an ARB or E-locker and likely an open diff too.
The OD of the RAX inner axle seal is 41mm so there is still a good deal of material there available if one did have to open it up a bit for a larger OD shaft. Could be a really neat option. What fails next?![]()
Or retro fit a 100 series third (stronger R&P), OEM 32 splined axles and custom hubs to suit the 32 splined axle flange bolt hole PCD and hardware
Or 100series 3rd, custom 32 spline axles, custom 32spline hub flange
It’s my understanding that the “newer” (98+) 9.5” gears and 32 spline differential will fit in 80 series and old 3rd member. So no 100 series 3rd needed, just the “guts”.
105 / 79 series REAR runs heavy R&P, 32spline a FF axles, larger diameter hubs with larger bolt PCD, 8mm dowels and 10mm hardware.
105 series FRONT runs same 3rd, same R&P, same axles, same birf, but hubs are beefed up to match the rear
ARB 152 fits normal Land Cruiser "9.5" third member...
Also Nitro already makes shafts it seems...
Nitro Pro Series Chromoly 32 spline Upgrade Axle Kit
Nitro Pro Series Chromoly 32 spline Upgrade Axle Kitwww.justdifferentials.com
I am not sure but it seems like 200s are semi float only...
The idea of using the 32 spline diff, shafts and a larger 100/105 hub side pattern and larger studs with the 80 6x5.5" hub is a near idea![]()
