I have a 30 mm deep socket, is there an issue with using a deep socket here? Also is 1/2 inch drive okay or is 3/4 required?
Thanks!
Thanks!
No I am using that special Otramm holder 1FZ-FE Crank Holding Tool then was going to make a breaker bar setup, but my only 30 mm socket is 1/2 inch and deep from this set here.Are you going to brace on frame and bump starter? You may or may not snap a 1/2 drive. I made a special to for this purpose that is a socket welded to a 3 foot section of 1 1/4 square bar. I think 3/4 if you can get one is best.
I snapped my 1/2" drive craftsman breaker bar like it was a toothpick.ended up with a 3/4" breaker bar.
Well I didn't get to it today, I ended up removing the valve cover to replace the gasket, I could remove three of the screws in the rear with just my hand which was where the most oil sludge was. Spent a bit of time cleaning everything. I've got the cover now and am considering painting or putting back on as is.
Very nice! Will touch up tomorrow, looking good so farPaint that puppy. And anything else that suits you.
View attachment 2421361View attachment 2421362View attachment 2421363
Do you have a picture? I'm curious how this looksI'd also recommend painting the upper air intake high-temp silver.
