3 years of collecting - Starting to build the 40. $200 (1 Viewer)
Mike,
Put the drivetrain in it first. Then do the suspension. Good prep work is the key. Use good jackstands.
I can't remember... didn't you get the Proffit SOA kit? If not, here is how I did mine:
1) Prep the front housing by cutting/grinding off all the existing spring perches. Leave a little of the bottom perch for a guideline for the new u-bolts.
2) Tack or clamp the shackle hanger in place using the springs you are going to use. Locate the hanger so the spring at full slack has a shackle angle more or less about 20 degrees. You will be changing this a couple times once you are able to get the full engine and tub weight on it if you want to fine tune your shackle angles. Tack or clamps should be sufficient to support the rig and located to easily grind off.
3) Install the front housing using the new perches and u-bolts and centering the axle in the frame as best you can. Here is where the old perches will help you locate where the ubolts should go and center the housing (assuming the frame and outriggers are square). You will need to work around the passenger side perch for the time being - don't cut it to match the housing yet. Just tighten things a little snug to hold things in place to mock up the axle. The clamp force of the ubolts will hold the perch in place and keep the housing from rotating.
4) Load the weight of the vehicle on the housing. Adjust the hanger locations to get the shackle angle you want. Some say 45 degrees is good. The springs will flatten over the first year so 30-35 degrees is probably a good starting point. Tack the hangers in place.
5) Rotate the housing using a jack under the pinion so the pinion angle is in line with the mocked up driveline or pointed at the t/case output. Note, a CV joint is much longer than a standard ujoint. Get a donor DL if you can and use that to mock it up.
6) Use a template or grind to fit the passenger perch to the housing. It should be the same height as the driver side and have minimal gaps.
7) Tack the perches in place.
8) Cut the housing at the knuckles. Rotate the knuckles to the desired angle. Say 3-5 degress depending on tires but do your MUD homework.
9) Tack the knuckles.
10) Inspect everything and finish other mods on the front end. Truss, brake line tabs, for example...
11) Pull the front housing out and final weld everything.
12) Paint
13) Reassemble.
I hope that helps,
Andy
Andy, Thank you! The engine / body will go back on this week. I didn't get the proffitts SOA kit.
Mike,
12) Paint
13) Reassemble.
I hope that helps,
Andy
Yep, running 60 axles. I had to rotate my pinion up 10 deg to get it to point directly at the t-case.
Yea... did you run 60 axles? I'm running 60 axles and got ruff-stuff for the outboarding.
I'm just getting hung up on pinion angle. Only want to cut/turn once. I think after I get over this hump, more progress on this build will come.
You are welcome Mike.
You are miles from having to worry about the suspension. Get the motor and drivetrain in with the tub on. That should be damn near running before you even start to screw around with the suspension.
Pick your battle and finish it before you start another. You have all the stuff to complete the motor and drivetrain. Start there and finish ALL of that before you do anything else. Then do the tub and electrical. Then everything else.
Good luck.
Andy
Good luck.
Andy
Ill second this!
Im in the same situation as you are...Contemplating which is the best thing to do first....
I have resolved for the SOA the best result will come from the tub and frame being as CLOSE to the running weight as possible. This is how I will be executing it any way.
Also, I plan to allow for spring settle (as mentioned above) by undercutting the shackle angle a tad. I discovered this when I did the 62 build...The pinion/ shackle angles were great, then the set up settled, and there was a visual difference over a couple of years. Never had any problems, but I could SEE that things had settled.
Keep it up my man!
Keith
Had to build a Canopy for my toys and junk and clean up my redneck front yard before I got any complaints... Body/Frame are back in the back yard for a while. Believe it or not, I'm 95% done with the Canopy setup... started at 7am on Saturday... hit 95% around 1pm today.
Few more pictures
Hey Mike! Awesome to see you working on this again! Not sure if you missed it on SCH but I have some 60 rear springs if you still need em? Lemme know if you need a hand again...
BTW you wouldnt happen to have a good 2F would you... ;)
Hey man... sorry, no 2F's right now... doh. I found some 60 springs in another pile in the bak yerd. Thanks.
hey everyone... 3 years collecting, almost a year building and now Slamming on the brakes on this project and Submarge. Its all For sale. I wouldn't say its a travesty, my family and friends mean more to me that hunks of well designed metal. I'm not getting out of cruisers forever, this is just a season. I'll be back... there isn't a better rig IMHO.
Stuff will be listed for sale in the classifieds. Pm me if you want/need something from this build.
awwwwwwww DRRRRRAAAAAAG!!!!!
Its all For sale. Stuff will be listed for sale in the classifieds. Pm me if you want/need something from this build.
Isn't it against the law to have a "Going Out of Business" sale every six months? :flipoff2:
