Did the solidworks model ever get built for this yet?
Interesting thread. I would avoid a draw through setup personally. Especially if you are trying to add an intercooler.
I have a spare Garret T-25 I thought about using for this type of setup. Of course I also have a 5.0 302 sitting under the pole barn that would be fun as well. I'm trying to go through my head and see about laying out all the components and would love to see the status of this project.
Tripper
You can not run a draw through set up with a gasoline carb. The fuel will freeze the turbo if you are below 50*F outside. Fuel will start to pool up at the bottom of the turbo and effectively start cooling it. I bought "Maximum Boost" by Corky Bell, and he was pretty much against anything draw through but he never covered propane.
Since propane is a vapor by the time it hits the mixer, it will not matter what temperature it is outside. Also with a draw through set up for propane the mixer will still think it is on an intake manifold and not on the inlet side of the turbo. The inlet will act like a vacuum source so the variable venture/diaphragms will react the same way.
You are kidding right???
Go look at Old VW bug turbo systems. Lots are draw through. And do very well at cold temps..
Do you know what it takes to freeze gasoline?????
Corky is an excellent resource. The reason he prefers blow through turbo's is because of throttle response. And the length of a "charged" pipe.
Jim Did a good job on his setup but IIRC he had some major problems with the intake manifold cracking..
jabxyz, there is no kit. Hopefully I'll have my adapter back today and I can start putting my 40 back together.. I'll list all of the parts necessary as I go..
No I am not kidding.
Quoted from my book:
"The primary concern in the draw through layout is the air/fuel mixture be permitted to flow downhill at all times. This condition is not possible due to the compressor inlet scroll, but no other item should be allowed to serve as a low point. Fuel tends to drop out of the mixture and puddle at the low points. Puddling will badly upset the cold idle and low speed response."
"A further addition of heat may be required to prevent carburetor icing when operating under boost. Typically, a correct air/fuel ratio will create about a 45*F temperature drop when the fuel vaporizes in the carburetor. This temperature drop, combined with a cool, damp day, will frequently cause throttle to freeze wide open when operating under boost. A fine cirumstance, cured only by adding yet more intake heat."
"Rule: The draw-through system is prone to icing at temperatures under 50*F"
*edit So I was wrong about the turbo freezing, it is the carb that will start to ice under boost. Either way draw through is not the way to go for a gasoline carb.
Given that I am strongly considering turbo charging the 2F what are the views out there regarding doing both, fuel injection and turbo. Do people tend to do one of the mods and not the other or do they tend to do both as they would seem complimentary tweaks aimed at getting the most out of what is reputed to be a very hearty engine.
I have begun to see references to fuel injecting the 2F engine. Same question, has a kit been developed for this yet? If not is there a parts list, pics etc. available from someone who has done it? Given that I am strongly considering turbo charging the 2F what are the views out there regarding doing both, fuel injection and turbo. Do people tend to do one of the mods and not the other or do they tend to do both as they would seem complimentary tweaks aimed at getting the most out of what is reputed to be a very hearty engine. Thanks again for suffering the newbie.![]()
Easiest way to inject a 2F is remove the head and bolt on, and it is a stright swap, a 3FE head which is injected. it will look like this
now where did I put my Turbo![]()
And then once you build it, you can let it sit there and admire it for weeks on end............ after all, it looks so nice on the stand who in their right mind would put it in the truck.![]()
I was already just beginning to think along these lines and then to be able to get hooked in to a group that has been there, done that and already has grease on the tee shirt is just great. I will now be an obediant newbie and read that thread front to back. Thanks so much guys, this site is great.Easiest way to inject a 2F is remove the head and bolt on, and it is a stright swap, a 3FE head which is injected. it will look like this
Matt, Rockdoc, you da menI was already just beginning to think along these lines and then to be able to get hooked in to a group that has been there, done that and already has grease on the tee shirt is just great. I will now be an obediant newbie and read that thread front to back. Thanks so much guys, this site is great.
he does it for real Don't lump me in with Matt, I build in my mindhe does it for real
