As Pin-Head mentioned, the hybrid points/electronic dizzy like you have is a very good system which can still get you home even if the ignitor goes bad.
Go to post # 46, first pic of the dizzy:
Look to the 11 o'clock position. You need to get 12V, with ignition on, to the bolt on the outside of the dizzy, through the nylon insulator block, and to the wire to the points on the inside of the dizzy, without grounding out.With the points open, like is shown in the pic, you should have 12V on the movable arm of the points.The arm is insulated electrically from the base of the points. When the points close they become grounded.
At the bottom of the pic, in the 6 o'clock position, is a screw head on the inside of the dizzy body, with a ground wire attached. The other end of this wire is fastened to the advance plate inside the dizzy. The advance plate holds the points, but isn't necessarily grounded to the dizzy body, except through this wire. This wire, and screw contacts, must be good shape to provide ground for the advance plate and points. All of these items MUST be in good condition electrically, and work together to allow the points do what they were designed to do.
Check out each item mentioned here, making sure you are getting 12V to the movable arm of the points, and not grounding out while the points are open. Then make sure you have good ground from the advance base plate and on through the dizzy body.
As an aside, in the 11 o'clock position in the pic, is a screw in a slot holding one end of the points base. Just to the left, and above the screw, is a notch in the points base plate. Just above that, on the dizzy advance plate, are two raised dots. To adjust the points gap you slightly loosen the screw, place a flat tipped screwdriver with one edge in the notch of the base plate,and the other edge of the screwdriver between the two dots. Use a twisting motion to open/close the points gap.
Don
Pin_Head thinking of your vacation in Raiatea:
There are a surprising number of local attractions here. I haven't gotten on the boat yet, so I still have wireless service.
