Build 2013 Toyota Tacoma Access Cab Chinook build
The walk through was cut out with no drama but it was scary to do...note in the side view pics all the air bag equipment. The side curtain airbags are still fully functional....
Ok, when you first said “air bags” I was thinking suspension and was a bit confused - never even considered the restraint systems… Wow!
PaToyota, I did not think to clarify that we were not talking suspension... this truck has front and full side air curtains..l scared the crap out of me as we contemplated the cab cut! I hope I never need them but it is nice to know they are there...
Patrick had a great idea to design an aluminum water tank that would make use of the heat coming off the tacoma muffler for hot water.., Hot damn, great idea. This is the start of it. The radius part will be 3/4" away from the muffler. According to my math...14 gallons.
The steel subfloor us off for ospho, prime and paint...
Well, I’m a bit behind the times. I don’t even own a vehicle from this century… :)
Fairing and getting the camper shell ready to mount and paint was the priority today... also some last details on the subfloor. Mounting points for the under body aluminum utility boxes and mounts for a subfloor fiberglass storage box... next the steel needs to be osphoed, primed and painted... it will be mounted tomorrow (hopefully) after the aluminum water tank is welded and then mounted......
Then the camper can be mounted!
More fairing on the camper shell and it is getting pretty close to ready to prime... still some fussing to do to mount the tacoma factory tail lights. Trying to mate these compound curves is a bitch. I am going to look for a rubber extrusion that could be used to mount the tail lights.... something like an H shaped glazing bead.... would make life easier and create a water seal at the tail light.
The aluminum water tank is dry fit together and at a neighbors shop being welded. Here is a pic to show how it will hug the truck muffler to give us some hot water. I will insulate the outside of the water tank except for the radiused surface that will be about 3/4" away from the muffler. After the water tank is installed the steel subfloor can be permanently mounted.
Made some head way today.... got the water tank back from my neighbor all welded and ready to mount below the subfloor tomorrow. Mounted 2 of the 4 aluminum diamond plate utility boxes and put the camper shell back on for the final dryfit. The camper shell permanent mounting is so close!
Home stretch for the permanent mounting of the camper shell. All the steel is done and the camper was put on for the final dry fit (finally).... it is looking great and it is amazingly sturdy with it just C clamped together. It will be a rock on Friday when it is all bolted and laminated together...
So here is the plan. Pull the shell off tomorrow. Pull the subfloor off. Ospho, prime and paint where needed for rust controll. Install water tank and stub in the fill, vent and supply hoses.
I have already cut to fit 1" divinicel structural foam for every section to be filled in the steel subfloor. Tomorrow I will laminate the bottom of each foam section with fiberglass mat then install them in the steel floor. The entire bottom will then get sprayed with undercoating.
Then the camper shell goes on and the camper gets fiberglassed to the floor. It will be very strong... the divinicel is closed cell ridged foam That is an insulator as well as very good acoustic sound deadening material. I will use a thicker foam over the generater... note the floor is raised about 3 inches over the generator. That small platform is where the tiny e way fridge will mount with a tiny dometic microwave on top of it...
That is what I am hoping to finish by Friday afternoon....
Oh...also I received the 2 will composit LP tanks and they are the bomb! Each weighs only 5lbs empty... they will mount externally on the back to supply the generator, heater, stove and fridge when needed...
So, tomorrow is the day to finally join all the pieces...pulled it apart again first thing this morning.... the steel frame is all painted. The foam floor inserts are all fiberglassed on the bottom side ... after the shell is installed the camper, floor and steel will all get laminated together.
It is a puzzle to put it together. The steel floor first then fiberglass camper then the steel floor has to be lifted in front to install the cab frame.? The camper shell is being sandwiched between the cab and the 1"x3" steel frame. The seal is being done with a butyl rubber gasket and 3M 5200 chaulk.... 5200 is one if not the strongest marine sealant.
I got finish on the back bumper using a shaker can bed liner. Came out pretty good! Also got the outer under rim of the pop up camper top painted in a white bilge paint and spatter coated with black. It will only show when the top is up... we are boat people and I am using materials I know from boat construction including the structural foam used in my composite floors...
Well I will not get to mount the camper until Monday. Just not enough time in a day. Had to cut and fiberglass the rest of the foam panels for the wheel wells and back corners. After fitting them it made sense to glass them in from the top....
I had planned on doing that after the shell was mounted. I had to not install a few floor panels where we need to mount the water tank. The inside of the wheel wells will, be fabricated in aluminum diamond plate and tie into the under body utility boxes. Monday the floor section comes off and will be sprayed with a rubberised black undercoating. Water tank goes in and then the camper gets mounted.
Got a coat of white primer on the pop up top as well...
Subbed as well - very cool build!
The camper is mounted! Rubber gasketed, tech screwed, through bolted and then the shell is glassed to the floor and steel frame...
The pop up top is temp mounted. the scissor ladder is mounted in the back bumper and the generator is finalised with the muffler mounted remotely behind the bumper.
Next the 4 diamond utility boxes get permantly mounted...
