2008-2018 Radiator Failure and Public Service Announcement (8 Viewers)
I can join the crowd now too. 122k miles on my 2008 LX570 and I have a hairline crack in the same spot everyone else does. Ordering a new radiator tonight and going to take a peak at the complexity of the starter and water pump replacement and may preemptively tackle those. Hard for me to find a day to devote to wrenching so I’d rather knock everything out and have peace of mind for another 100k.
Did your coolant started to leak? Wish I had the time and patience to wrench everything else myself.
From what I hear, the starter is a pain. Something about needing to remove the exhaust manifold, etc.
It can be done without manifold removal but a couple of the starter heat shield bolts are damn near impossible to get to with it in the way. Or, like me, you break off the downpipe studs getting that out of the way and need to remove the manifold anyway. Oh, and mine is a relatively rust free truck. Fwiw
I’m on mobile or I’d link some recent posts on it.. check a few pages back in the “what did you do to your 200” thread or find Teckis’ thread on “starter failure mode”
It had failed as others had described in the begining of this thread. It’s actually what prompted me to join the community here. I think it failed at about 75k or so.
After looking at your quotes, I think you’re right about the Lexus upcharge. Did you consider taking it to a Toyota dealership?
Thanks for the suggestion. I called a local Toyota dealership; oddly enough the costs are even more than Lexus dealership #2 I called: $1275+tax, and this is with aftermarket parts. Per tech, OEM would cost more. I also inquired about starter replacement: $1660+tax.
No leak yet. Watched a couple videos on the starter replacement. Doesn't look like you really gain much in terms of reduced complexity doing it with the radiator vs as a stand alone project. Can anyone comment on the validity of this? If that's the case I'll probably just wait on the starter. Water pump on the other other, looks like the extra room from removing the radiator would make that job a fair bit easier so I'll probably knock that out.
Radiator in/out has almost no impact on starter R&R. The closest you’ll get to it is removing the upper bolt on the dipstick tube to remove it.
Wow! That’s a bummer.
Yes, completely unexpected. Perhaps my local Toyota dealership equates Lexus with ability to up charge.
I'm going to try get a few more quotes. Main problem I have is time (and need for a loaner).
Update: Got another quote from a nearby Indy that is highly rated. Got a good vibe from this one fwiw. Service gal I spoke to actually did not recommend I replace the radiator and starter pre-empatively. She recommended I get a inspection ($30) to test for starter voltage/excess draw, and to also inspect the radiator for hairline cracks.
  1. Replace with new Denso radiator, $950 total. Takes about 1 day due to need to burp the coolant. This shop has local shuttle service, so I could drop it off in the morning and pick up by end of day.
  2. Also asked about replacing starter, ~$800, takes 1/2-1 day.
Such a massive difference in price compared to the Lexus and Toyota dealerships. So question: are Denso radiators OEM quality?
There's also a huge disparity between dealers sometimes.
The OEM Radiators are Denso.
If you go OEM there is a chance you get the improved upper tank. But only a chance. Not sure what the densos look like in that area.
Also their starter test shows ignorance to how our starters fail. It is usually not a starter motor issue, but the solenoid aka contactor. This wouldn’t be evident with an amperage test.. they just stop working sometimes with no warning.
In the earlier pages some members have replaced radiator model with Denso. The comments were it was a perfect fit. Denso is good manufacturer.
Have you taught about renting a car? Enterprise's moto is that they will pick you up.
When I had my radiator replaced on 2013 lexus lx 570 with hairline crack, I took lyft home. I had radiator, termostat,upper/lower hoses, idler pulley, tensioner, and water pump replaced. I called several (4) lexus dealerships. I called highly rated independent lexus/toyota mechanics from yelp. I asked how much for labor for all those items. Some stated each item would be a separate fix. But based on this thread, I knew before hand that all those items would be easy accessible. It is about 4 hour labor hours billable. I called the mechanics listed on this forum for my region. He agreed it is only a 4 hour project. Charge was less than $400 for labor. I scheduled an appointment. I purchased parts from one of the discounted dealerships.
I dropped it off in the morning. I took Lyft and he called by 2 pm that it was ready. I took lyft back to pick up the lexus. He provided old parts and stated everything still looked in great shape.
I have called Lexus dealerships for starter replacement. I have been quoted between $1200 to $1,400 which includes part and labor. It is 3.5 billable hours. I know i can purchase the starter for about $350 from one of the many discounted toyota dealerships who sell parts discounted. I will schedule with the same mechanic.
Oem radiators are actually toyorad. I am guessing. Denso is the oem starter. I don't think there is even a after market starter. There is remanufactured/refurbished ones.
Oem radiators are actually koyorad.
I was wrong about Denso, but I'm not seeing Koyorad...unless TRAD and Koyorad are the same company.
Nevertheless. I would trust a Denso. After all the original TRAD part is what has been failing.
Docboy, your price is probably just about right. Two weeks ago I backed my 4runner over a fiberglass snowplow stake in a driveway. The stake found it’s way thru the suspension and punched a hole in the radiator.
The bill for an OEM radiator, thermostat and coolant was $731.
Cracked plastic top radiators are not exclusive to 200’s or any vehicle. My Nissan had the same hairline cracks that you guys describe. Like an idiot I postponed the repair. The engine overheated for about 30 seconds and when I got to the top of the hill cooled right back down. I replaced the radiator myself. Six months later the knock sensor and a head gasket failed, the engine overheated and my Xterra was toast.
That Xterra had 253K, and an engine rebuilder told me that it’s only a 300K mile engine so I did not lose a whole lot when I scrapped the truck.
How many gallons of coolant are needed if the water pump is also replaced? Is it still two?
What is the part number for the clamps on the upper and lower hoses? I can't find it anywhere on the parts diagram.
My recently purchased 2008 LX570 has 132k on the clock. The water pumper was replaced around 60k by the dealer. Think it's worth it to replace it again once I have the radiator off?
Are most people doing the thermostat at the same time?
Two gallons approx. Water pump and radiator are two different animals, and separate jobs. Do replace the thermostat though. Good insurance.
My Turn! 09 with 132k. I bought this truck last summer in TX. I didn't notice (or know about) radiator problems before shipping it to USVI. We have a Toyota dealer here but I'd only take it there as a last resort. So, I ordered everything from RockAuto. All parts fit fine and it took me a day to do all the work. (Radiator is a TOYORAD) Looks like the same exact design with built in Failure point. But, it's back on the road w/o any leaks. Thanks to all that post incredibly helpful information on this forum. Cheers! 🍺
1913777
1913778
1913779
