So I'm a huge fan of my factory locker, but I've heard others say they would prefer an air locker. Why did you choose the elocker for the rear when you could just do two ARBs?
I started taking things apart today to see what went wrong. Something interesting came out of the front diff when I remove the drain plug...nothing. No teeth, just above average shavings and oil.
Very confusing. I think the teeth are stuck inside.
If it's like the 80 series, the housing is different between the E and Non-E-locker axles.I'm still not sure why you can't just plug the oem elocker into your current housing. Swapping axles just for a locker is way more work than it needs to be.
Sure looks like a piece of tooth in there to me. Only takes 1. That one tooth can bind on the way down. If you have a long flexible magnet, or if you can get your pinkie finger in the drain hole, you'll probably find more.
Better yet, spin the tail flange of the differential with your hand. Just past the 4th turn, it'll probably bind up and there's your break.
What else did you take apart?
I believe there's a notch in the housing where the elocker actuator sits, where as a regular open rear end would not need that notch. I have heard of cutting the notch into your housing, and I know that's pretty common on the 3rd gen 4Runners and equivalent gen Tacos. Anyway, /hijack and makes total sense to me @2000UZJ. What are your plans for actuation of the lockers?i thought only the third was different between locked/open 80 housings? but then again, i haven't looked at a open 80 rear housing.
Two things:
One: do the TJM front locker. It's cheaper and stronger than the ARB. I love mine!!
Two: don't get 5 point restraint for your seats. They are a hemorrhoid getting in and out every time. You will get tired of them quickly if this is your daily driver. I've had them in my pre-runner Baja bug that was street legal and it was always a pain having to use them unless I was really off-roading and jumping.
This is a pic of an 80 rear end that shows the part to trim and the holes to tap to add the elocker.
I would figure a 100 would be similar but have no first hand info on that.
I only needed to notch the housing when I stuck an 80 e locker into the front of my 62. But I talked to nick and found out why the whole axle would be swapped lol.
...via IH8MUD app
What's the reason? I'm sure it's a stupid simple answer I'm overlooking. I know the gear ratio changed in 2003 when the trans change but why can't you do it in the 98-02?
