200 Series Tire and Wheel Size Database (14 Viewers)
For anyone who just skipped to the end of this thread, I will save you some trouble ...33s are as big as you are going to be able to run without extensive modification.
Considering jumping to 17x8.5 0" offset Method 702 w/ KO2 285/70R17 116Q. Also considering Icon Vector 17x8.5 25" offset if that would reduce any rub.
2013 LC w/ stock suspension. How much rub would I experience if any?
0 offset- lots of plastic adjusting/heating/molding/trimming and removal of front mud flaps
+25 offset- minor plastic adjustment and most likely remove mud flaps
By minor adjustment do you just mean using a heat gun to make room? I would prefer not to trim anything.
You won't need to trim. Just remove mud flaps and heat gun the front of the fender liner forward a bit
I'm looking at the Goodyear MT 33x10.50x17 but it's only D rated at 2910lbs... any input as to it rated high enough?
That's plenty. Do you plan to put 11,500 lbs in your rig? While you're looking at skinnies take a peak at kenda kr601 35x10.5x17, also a D rated 3 ply sidewall, hybrid not full mud.
thanks for the reminder @grinchy on the Kendas! I'll look into them. also, looking at the kanati Mud hog(old Goodyear MT pattern) a buddy of mine has them and really likes them!
Maxxis Razr MT looks like a pretty good MT option too. Pricey.
just found this on the Kenda website.. posted by an unhappy customer... FWIW
Goodyear also has a 275/80/17 option if you wanted a bit bigger..
(aka can you get those and tell me if they work
... hahaah
... hahaah
That's a great option I wasn't aware of. Thanks for pointing out. I run 275/80/18 right now, and have been looking for a slightly smaller mud option. I like 275/80 on the truck . . . slim is in.
I really like the 275/80 but i have 8.5" wheels ... vs. the recommended 8" NOT sure how big a deal that is ..
None. The range for 275 goes up to 9"wide rim.
It's certainly enough tire as far as Load Limit goes.
The RCTIP for a 33x10.50R17LT tire on your 2013LC200 is 46psi F/R.
HTH
