200 Series Tire and Wheel Size Database (12 Viewers)
LX570 tire size ?
So 275/65r20s would appear to be a 34" tire. You guys mentioned a lift is needed in a 200 series. How does this apply more specifically to the LX? Would it be fine around town and when off road just simply use the AHC setting into high to clear the larger tires when articulating? I ask because the same width tire size with 1" smaller diameter (275/60r20) or 33s, has been posted that it would clear with no rubbing on a stock LX..
Firstly, lift has nothing to do with clearance for tire size. It's a misconception from the solid axle days, where lifting changes the functional suspension stroke. On an IFS, regardless of your lift, the tire still works within the same stroke. Just the resting point is at a different position. When articulating, the suspension still travels the exact same stroke, so you will want the tire to fully clear on compression.
To make it more concrete, the front has 9" of suspension travel. Normal ride height for example is at 4" remaining compression (5" droop). Lifting might change that to 6" of compression (3" droop). The suspension still travels the same stroke, just changing the neutral point.
The LX570 AHC suspension doesn't change any of this geometry. It's a different technology applied to spring and damping, but the arms and everything are the same, so same stroke and fitment applies. Other than we don't have the KDSS sway bar to interfere for wider tires. Though our sidesteps are a bit more prominent and may need cutting at the inside leading edge when fitting large diameter tires (~34") and aggressive offset.
To get to your question, 275/65r20 are on the big end. Can it be done, yes! It will need a bit of tucking and cutting of the plastics surrounding the wheel well. Much the same as would be done on the LC. Relatively easy mods (if you're okay with cutting), which in my mind is not a big deal, but it is for some.
Lifting is a separate question that comes down to your wants. AHC can easily be lifted ~1.5" with a 10mm wrench on the AHC height sensors. And still maintain full use of L/M/H positions, which will all be ~1.5" taller at their respective positions. Combined with the tire lift, that'll be over 3" of constant height lift. Plus you'd be able to manually select H, which puts you up to almost 6" lift overall.
Has anyone done this? Love to see some pictures.
LX570 tire size ?
Teckis already answered well, but I’ll add that I put 275/65/20 KO2s on my stock LX570. Removed the mud flaps on the front wheels and was good to go. Keep in mind a KO2 runs a little smaller than many tires in that size, so YMMV.
Neutral/high/low:
Neutral/high/low:
View attachment 1656923 View attachment 1656924 View attachment 1656925
Damn that's badass.. If all I need to do is remove front mud flap in order to fit this size, I am sold! I will be doing the 1" 5 min adjustment mod that has been posted here..
Yep it’s easy. Flexes nice with the size too and doesn’t rub anywhere.
New tires! Yesterday I had 275/70r18 BFGoodrich KO2's installed on my 2014 LC. Only mod is the Toyota leveling spacers. So far no rubbing, but have not been offroad yet. Will post back if I ever find rubbing.
Just for the record - Discount Tire will price match and even beat Tire Rack's price by about a hundred dollars after factoring the road hazard warranty!
I mounted up a set of 35x12.5x20 Toyo At' Extreme's today - very impressed so far ! smooth as butter and have full travel.... will get some pics up this weekend.
loved the ridge grappler but these have a much wider footprint and roll super smoothly.... and with the ARB's they should suffice...
E
E
Does this mean you’re keeping the 200? Are you coming out to LCDC this summer?
I have the following:
2017 TLC
BFG TA KO2's
285 65 18
stock wheels
0" lift (stock suspension)
tire pressure 42 (all the way around) - I emailed BFG and they said for my vehicle if I set it to 50 psi it would support in excess the load capacity set by Toyota
fits in spare tire location without any modification
no spacer
no rubbing
I went with the same tire in my 2018 TLC.
BFG T/A KO2
285 65 R18
stock wheels
No rubbing around town. Have not been off road yet since I just got them.
How did you determine 42 psi? The tire shop inflated to 34 psi and it drove terribly, so I raised them to 39 psi. Is 42 psi cold what I should take them up to?
BFG T/A KO2
285 65 R18
stock wheels
If you have the LT285/65R18/E 125/122R Part# 16168 BFG All-Terrain T/A KO2 tires and are running them on a 200 series Land Cruiser, then the Recommended Cold Tire Inflation Pressure for that application is 42psi F/R.
HTH
Thanks gaijin! I will raise them to 42psi all around.
Hey @gaijin - what psi do you recommend for 285/70/18 Nitto Ridge Grapplers on OEM 2016 wheels?
Hey @mcgaskins - I assume you mean LT285/70R18 E 127/124Q Ridge Grapplers, and I assume you intend them for use on your LC200. If those two assumptions are correct, then the Recommended Cold Tire Inflation Pressure is 38psi Front/Rear.
HTH
HTH
Yep correct! Sorry I should have specified. I've been running them between 37-40psi, so I'll keep them where they are. Thanks!
BFG T/A KO2
285 65 R18
stock wheels
Gaijin confirmed 42psi and that is also what BFG emailed me.
Alright I’m having a hard time with tire selection after reading some threads and the tire database. Right now I am running BFG KO2’s in 285/65/18 on a stock 2017. I have a BP51 kit and UCA’s on order. I’ve become a big big fan of the Cooper ST MAXX tires and would like to try and run them. The options would be 275/70/18 or 295/70/18. I have read some threads where the 285/75/18 Nitto Ridge Grappler’s rub. The 295/70 Coopers are slightly shorter and slightly wider than the 285/75 Nitto’s so I’m guessing I may also have some rubbing. I could remove the front mud flaps and that would help some but I would like to avoid cutting if possible.
Oh and I have the stock 200 wheels and also a set of TRD Pro wheels. I believe the TRD Pro’s will result in a more narrow stance and potential totally increase any rubbing potential. It appears the database has not been updated in a while so I am hoping maybe someone out there has tried a similar setup. I would also consider spacers if that might be helpful.
I just put 285/70/18 Nitto Ridge Grappler’s on my rig with SPC/Light Racing UCA's & BP 51's on stock LC wheels and had small amount of rub on the inner half of the front mud flaps. I trimmed the mud flaps substantially and re-installed. No more rubbing.
Nice to know, was thinking about this specific tire after I upgrade / lift my suspension on my 2010. Are you using spacers along with the stock wheels?
Thanks again for the update .
