200 Series and Tundra wheels on 100 series photo thread (2 Viewers)
BBS
I'd like to get out of this spacer game with my Tundra wheels. Can someone that went the route of flattening the dust caps post a picture here so I could visualize how it looks finally?
Noob wheel question - I have an '06 LC, which originally had 18's per the placard. PO put on nice Fuel rims with MTs. I will keep those for any offroading, but want stock wheels for daily/ interstate driving. I see lots of 200 series and Tundra 18s for sale locally and on ebay. Are those 200/ Tundra 18s just plug and play for my '06 LC given that I think they have the bolt pattern (5x150) and offset (30-50), or is some other modding required?
If the wheel has a center bore that is less than 110mm on both the inside/outside, it will not fit the front without spacers/wheel adapters. Whether the center cap fits is dependent on design. But typically wheels with "bulbous" center caps will fit.
This Tundra wheel won't fit without a spacer.
18x8 Toyota Tundra wheels oem 2007-2013 Silver rims 75179
thanks. what about this style from 200s?
I'm not 100% sure because I can't measure it but looks like the same issue. Bore too small. The wheel needs to look like this.
When shopping, just have the seller take a picture from the backside of the wheel of the center bore without the center cap. If its the same all the way through, it should fit. (cap fitting is a different story).
Based on @SOTXcruiser 's post here, they'll fit. He used a spacer, but I'm assuming it was due to the tire size
Wah00 was asking if they were plug and play. You can make some 6 lug wheels fit with a wheel adapter.
I have those on a 2005 LC. They definitely require a spacer but very happy with them along with 1.25" Spidertrax spacers from Slee. Heads up turning radius is affected with spacers so be careful until you get used to pulling into parking spaces. Cost me $400 extra for swapping paint with another car.
Mounted 275/70 Grabber X3's on my $150 set of TRD Tundra's yesterday (FB Marketplace Score).
I ordered Bora spacers Monday, but it sounds like I'm going to be waiting on them for awhile... Anyone else order Boras recently and feedback on the leadtimes? I really want to knock the spacer/wheel install at the same time, but not if I'm going to be waiting a month or two...
Wow. Major score. I’ve bought 3 sets of these for minimum of $400. Are you running spacers strictly for looks? I’m on the fence with the same spacers. Following…
Yea, purely for looks. These wheels seem like they're made for the 100, the spacers just turn it to 11 😅
Yep, I hear you. I've never run spacers on any of my 3 Cruisers due to bad things possibly happening but have been temtped to.
Help - I'm having Tundra 18's put on today, and was just informed by the shop that the center caps don't fit on the front wheels when installed. Will someone remind me what the fix is for this problem? I've tried searching but can't seem to lay hands on it.
