200 Series and Tundra wheels on 100 series photo thread
Won’t be able to get it mounted until tomorrow but already looking good from powder.
Here are some 2-tone 18” Tundra wheels with 275/65 R18 Toyo Open Country AT/3s on the War Wagon. I pried the Toyota Ts off and glued on some EBay Ls. I used a 3 pound sledge to pound the grease caps flat and dremeled out just enough plastic to make the hub caps fit. I think it looks pretty boss!
I did the same to mine. I think these are perfect for the 100's.
The only issue I am aware of is the front center caps will not fit without some modifications. On my post above #242, the front center caps fit just fine after flattening out the dust cap and grinding out a little of the inside of the cap.
I just picked up a set of 20" wheels off a 2018 Tundra Sport and I'm running into the same issue. How did you flatten the dust cpas and how much can you grind out of the inside of the cap? These seem way too flat to go fit on the front of my 1999 LC.
I clearanced my dust cap about 1/8”, and popped the logo cap off of the center cap of the wheel and used a 1-1/8” spade bit to clearance the center cap approximately 1/8” more. Just go easy and remove some material, test fit, etc, until you get the room you are looking for.
Installed Tundra 18" wheels that came with 265/70/18 and removed the running boards
hey @unleashd , this is such a great looking wheel setup! did the front caps not fit on? and if not, could the center be dremeled out to get them to fit? I thought I remembered seeing someone say that once, but I found a set of these locally for a good price and am considering this setup - thanks!
Hey @dubitup , this is still the best looking wheel setup I've seen on a 100 series ! I have a black 07' and have been keeping my eye out for a set locally for a while, and just finally found them! how did you get the front cap to fit? did you have to cut the center part out or something? thanks!
The front dust caps can be made to fit in a few different methods
1. Zero creativity, which I adopted - Use spacers
2. Creative method 1 - Use a hammer and carefully flatten the dust caps
3. Creative method 2 - Use a dremel or hole saw to cut a hole in the dust cap to fit the center caps
4. Creative method 3 - Design your own and 3D print the center cover, slap a Lexus logo on it
