200 favorite Rock Sliders
what are the best rock sliders for the 200?
  • Total voters
    325
I'm trying to find the lightest way to have decent but not rock-garden-bulletproof protection for my 2018 LC. I have a Jeep for rock duties, and my LC will serve as a much lighter duty overland camping rig and possible tow vehicle. So, I want more than bare running boards in case I do something stupid, but don't want or need to add over 100 lbs of weight that can withstand what these sliders can, as gorgeous as they are. These were mentioned back on page 2:
Any pics of these protection rails anywhere? I can't find them on the website
Any chance Bud could make a set of his step sliders in Aluminum instead of steel? I like the design, I like the fact that they don't use nutserts, I just don't really need this much weight and protection.
I know Dissent is working on an aluminum set, but options are always good. Thanks
Yeah i'm with you on Riv Nuts. Where I loose my mind on them is when they loose their grip with the metal that they grip around, and you are left with a spinning bolt and nut that has to be cut off, then you loose the riv nut in the frame rail... which just bothers me. I removed a slider about a month ago that was held on with those things and yeah, spinning riv-nut.
Anyway, aluminum "sliders." We run some very... very high quality aluminum materials that react very nicely when welded that allows for polishing as well as eliminates corrosion naturally, it also has a higher weight to strength ratio than what most people use. It's much harder to work with but hey... we got Bud with his military aircraft engineering background and Will who was formally educated by the military to weld aircraft aluminum, so it’s doable. But honestly, aluminum as a slider just don’t hold up well to rock dragging. Aluminum just galls too much. People think it gets deep scratches, no, it’s actually peeling itself away due to its low lubricity properties. You can get away with aluminum on skids simply because there is so much more area to impact. So the odds of you hitting the same spot over and over and over are far less which basically spreads out the beating. But on sliders, you really only have a small, regularly impacted area, and it doesn’t take long before you just start to wear through that area.
As @mcgaskins said, the real weight difference sometimes is not much, it all depends on how much material is used. Aluminum is light, but you have to use more of it to make it the strength of steel (generally). Now just for our steel sliders they weight about the same as what else is out there. They are just more support than the rest to minimize deflection and bending.
77 pounds with full dimple die plates. The extra weight of BudBuilts is in the massive 3/8” inner frame plates and 5/8” bolts that give one hell of a solid mounting design. So is a weight penalty of not having to use riv-nuts worth it? That’s not for me to decided, but I just like to give the info, and let people make their best educated determination based on their needs.
BudBuilts are pretty overly tough, @mcgaskins showed a video of Slee sliders, however (sorry Matt) that was a pretty weak impact. But... for most guys, @sleeoffroad are probably up to the task for what guys are doing. Plus you can get Slee sliders like, immediately. When I bought my Slee sliders before I moved back to east coast, where I reconnected with Bud, Christo had those things to my door in like, 4 days. Pretty dang good if you ask me.
BudBuilts are just more about customizing and hardcore wheeling protection. Hell, we have over 150 different combinations you can make a 200 slider in on the website. If we made only one option like Slee, yeah, that would be too easy to stock. But we don’t, we let people put their own spin on it, and thusly, we have to build everything to order. And that’s the issue, we make everything ourselves, in house, so we can make those tweaks easier than companies that have other shops build their armor. One is not right and one is not wrong, just two different ways of doing things based off what these personalities want.
When it comes to overlanding use, you can’t go wrong with almost any slider available for the 200 (except for two, one is viper and the other I can’t say who it is, but damn, it’s a joke). But BudBuilt, Slee, Trail Taylor, White Knuckle to say a few all have good options, and some are just better for some people’s intent (strength or looks) than others are. No harm done, just how it works.
For our protection rail, it’s basically really good for bottoming out protection, like that video showed, it’s just offers no “lay up against a tree” protection as it doesn’t stick out enough. It does weight about 25 pounds less per side. Email me and I can get you some higher quality pictures than what’s on my phone right now.
As an alternative to true sliders (particularly if not rock-crawling), the ARB Side Steps are a nice solution. I have a set on my Tacoma, and they're very stout. Here's a link to the ARB site for the LC200: SIDE RAILS & PROTECTION STEPS
Here's a pic mounted on my Tacoma.View attachment 2000530
That’s actually what I recommend to guys wanting aluminum sliders. Go with ARBs for their light weight and far cheaper price. They also look pretty good to.
Just don’t hit much with them regularly.
Spoke w Kevin at BB today. Lead time is currently 10-12 weeks for 200 series sliders powder coated.
Order placed w Bud today for 0.120 DOM, rock sliders, kicker, full diamond plate fill, powder coated to match the front Metal Tech bumper that is now in transit.
Almost went 0.188, but learned the frame will break before those sliders. Although I don’t anticipate 21,000lbs of downward pressure, I’d rather the slider bust than the frame if that ever happened.
Kicker was an easy decision since I have young kiddos in tow and plan for a roof rack. And reflecting on squeezing through Steel Pass in Death Valley, a kicker would have been an asset.
Hardest decision was plate fill or not. Almost kept it bare, but then thought of the little kiddos legs falling through, little body continuing to fall out of the car and all kinds of unhappiness ensuing - and that mental image led to deciding on some sort of fill. Went with diamond due to practicality of increased traction in rain, ice, snow, etc.
Form follows function, at least in theory...
The sliders definitely don’t need to be beefier than the base model. I hated the way the kicker looked, and was too wide to fit in a carriage garage style garage door opening. The straight had plenty of step room imho.
Spoke w Kevin at BB today. Almost went 0.188, but learned the frame will break before those sliders. Although I don’t anticipate 21,000lbs of downward pressure, I’d rather the slider bust than the frame if that ever happened.
I’ll correct Kevin when I get back to the shop. Ultimate sliders are still not stronger than the 200 frame with how Bud designed the mounting system.
They get pretty close, but .188 DOM, even with our 6 legs, will fail before sending the damage to the frame.
Well, shoot, in that case one follow up question. Gather you may have a young’un yourself from other posts.
I was considering the 0.188 DOM w no filler. Seems there’d be a slightly better foothold with the slightly larger tube. Wrap it w skateboard tape if additional traction is needed. Question is, am I paranoid to think a toddler could get sideways w a non-filled ultimate slider w/ kicker on a 200?
We are on number three, four is a little more than a twinkle so we are long passed the bubble wrap phase w our kids, but have some semblance of caution remaining...
Do you feel there is a down-side to a filler? Personally, I don’t...but we all have different thoughts & needs.
I had no filler on my 100 Series’ sliders...but have been quite glad that my 200’s sliders were “filled” with a step-friendly surface.
But meh...
A great bonus to dealing with BB is that you get to customize to your liking. If a step-surface suits you.... Why not?
Naw, nothing against a filler; current order has it as I erred on conservative side w putting a full plate diamond filler on the .120 DOM. Just see a lot of diamond filler or dimple down sliders. ;Perhaps for good reason.) And my contrarian preference would be for something a little different.
So, I just go back to the BB pic of the white 5th gen 4R w/ blank ultimate sliders and a kicker. (Below)
Given Taco2Cruiser’s comment about the way the .188 ultimate is mounted safeguarding the frame, it got contrarian me thinking again about maybe going that direction.
My main concern, silly as it may be, is whether little kiddo legs and feet would have issues w/o a filler.
And, yeah, this concern really may not make a difference between a non-filled .120 or non-filled .188 but my simple mind looked at the .120 tube next to the .188 tube and thought, “hmmm, would the additional foot purchase of the .188 make a difference in sufficiently diminishing the need for a filler?”
To your point, and I highly respect your opinion perusing this forum and in our prior interactions, most ppl will likely be glad to have them filled at the end of the day. And a full diamond or dimple fill is a safe and logical choice.
Lol at this subject. I can almost guarantee that practically no one needs the .188 sliders. The standard DOM are incredibly beefy, and already weigh a ton, which noticeably affected the heft of the truck. IMHO, the bud built straight sliders are the absolute best slider option for the 200. Fit, finish, install, everything. I sold my 200 to downsize, and I almost miss the sliders as much as I do the truck. Stepping on them felt nothing like a “step side”, and more like the hull of a battle ship.
Bud built sliders received a couple weeks ago...
Installed them my lonesome this weekend.
Wasn’t too terribly difficult, just time consuming.
Very well pleased w the BB sliders. Ordering experience, customer service, build quality, installation instructions - all excellent.
Really like the design / installation approach where the existing holes in frame are used rather ingeniously.
Feels like an extension of the frame, though they should bust off before the frame would be damaged.
Custom powder coat coloring (to match front and rear bumpers) was a detail Bud’s guys really took seriously - which is appreciated.
No regrets: would do it again just as turned out.
Quick question on these - how much further do they stick out than the factor running boards. I want something that has a little more width - kids keep slipping out of the LC.
You might want to check out the flat steps vs the angled sliders. Not quite sure where to measure from, but they do have a good amount more of a step than the running boards. Also feels about 1000x more solid when you step on it. I believe the option i ordered was called "step sliders".
DPA200’s flat, non-kicker BBs are good looking, too.
Will provide some stats for the angled w/ kicker option BBs later when back home for a compare and contrast - unless anyone wants to beat me to it :)
Either way, can’t go wrong. Find what meets your needs and get her out in her natural habitat protected and ready to play.
Thanks for the quick response and the pic... I take a measure on the factory here shortly to see the difference.
no real clear way to measure these as far as how close to the truck to start to measure. The running boards have a clear step area only. these have the diamond plate top....but your foot also goes on the inner and outer tubing too. id say actual useable step part with my foot on is about 7", because my toe can tuck in under the body slightly. Anyway, can't go wrong with any of Bud's options. I have young kids and did the flat step, but they woulda been fine with the angled up. Kids can climb anything. Now old people like G'ma i say would have a way harder time with angled. Last time i had my mom in the car i had to use MaxTrax and wood block to build her a make-shift staircase up to my sliders. But she lives far away so thats a rare occurence
BB rock sliders at the “not kicker” portion stuck out exactly 2” more than the factory step.
BB step sliders stick out 2.19” further than the factory step.
measurements where taken off the frame to the furthest most point of both the factory step and the BB sliders.
Those measurement can vary as the body is almost never plopped down perfectly on the frame. The body can be up to a 1/3” further left or right depending on where the factory dropped the body.
