looking for suggestions... my ome fronts came with a nylon locking nut that is so hard to tighten that I’m about to start over with non locking nuts. I’ve got a 8mm wrench on the flats and a 19 ratchet on the nut and I am pulling so hard that it’s starting to round off the flats and I havent even gotten the nut on enough to compress the bushings yet... I’m wondering if I use a heat gun on the nylon nut to soften it if that might help
Reach underneath and hold the top of the shock housing with your hand while tightening. If you have a strap wrench to use on the shock housing, even better. That tiny 8mm part is nearly worthless to grab onto.
On the passenger side zip it down with an impact. I wasn't able to make an impact work on the drivers side.
