- Thread starter
- #61
This is a HUGE help in making sure I’m not missing anything before putting the hoist on the motor and yanking. I really should have started by looking at the FSM.
I had the same thoughts about nickel copper, bending was a bitch, and then it almost always had a slight kink in it. I have dave 4x4 hunting me late 1hdft model year fuel lines. We'll see.Some small updates, I pulled the tank, removed all gas, and swished with fresh diesel. Not a whole lot of varnish in the tank which was nice.
Swapped the fuel level sender to the diesel pickup and installed in the tank.
Removed the flap from the filler neck - I had never felt like a dentist until this this, with picks, a light, and and dremel all on one small place.
Applied stickers because I couldn’t help myself. I need to get that fender flare re-attached.
Lastly, I started running the 12mm fuel supply line and was planning to use nickel copper lines but really didn’t like the result I was getting with them. Going to look into other diesel safe solutions - rubber or ptfe maybe.
1/2 or 12mm line is alot harder to bend then the smaller sizes. Copper nickel is nice compared to aluminum or steel line though. In 1/2 they make different thickness. The thicker line is easier to bend.I had the same thoughts about nickel copper, bending was a bitch, and then it almost always had a slight kink in it. I have dave 4x4 hunting me late 1hdft model year fuel lines. We'll see.
we usually use 18 gauge (approximately 1.2mm wall thickness) 1/2in steel pipes, also easier to make it in three pieces, use a union or flare fitting or whatever works for youI got about a quarter of the way through bending when I tossed a huge kink into the line. Life is hard when you're stupid.
@TheBussman Do you have any rec's on NiCopp line with the thicker wall? I was using Summit Racing's white label line, Looked to be supplied by "TheStopShop" with nominal wall thickness of .028". Is there a bender you've had good results with?
Ultimately I'd prefer to go hard lines vs soft if possible.
Edit - looks like .035" wall 1/2" in line is available online. May attempt this again before going the non-hardline route.
I used .040 aluminum but copper nickel would be better. some people use the higher grade copper tube from the hardware store too, its not high pressure after all. I don't have any data in front of be about the cold working/vibration resistance properties of each, may look into it. Kinks do happen from time to time. I have an antique OTC bender that I should upgrade. The top of the line harbor freight bender looks pretty nice. I'll prob get one of those one day.I got about a quarter of the way through bending when I tossed a huge kink into the line. Life is hard when you're stupid.
I feel this, I got hit for 500ish in tarrifs on my PDI intercooler kit.....Also, PPD stainless 3” exhaust with muffler should be here tomorrow. Tariffs are eating my lunch on this one.![]()
Well lets get her in there!!!PPD HDJ80 system - looking forward to hearing this in person. View attachment 3984872
That's my sentiment too, but there are a few things that will be easier to sort out while the drivetrain is still out:Well lets get her in there!!!
