1FZ-FE block/head sending units??? (1 Viewer)
Anyone that could help? Thanks.
Go to one or both of the following and plug in your VIN to get the correct part numbers you need. It's easy to do.
www.partsouq.com
This is what I have
Just make sure they are for your year model as mine is a 94. Everything except the O2s should've the same. . I order everything from toyotapartsdeal.com you should be able to fi6the temp sensors
I think these are the temp sensors
Here's what I got:
TVV - 25820-13020
ECT sensor - 89422-35010 (needs washer - 904301-2005)
ECT cut switch - 88790-60050
ECT sender gauge - 83420-16040
Our part numbers are the same except for the ECT sensor, mine is 89422-35010 vs yours is 89429-34010. I checked both for compatibility to my truck which is a 97 and double checked with my vin. Both sensors are compatible with mine. So now the question is, are they interchangeable or they are on 2 different locations and both are needed?
Here's what I got:
TVV - 25820-13020
Looks like 89422-35010 is the correct one. Basing off otramm's video, it looks very similar. Looking closely at the diagrams, 89429-34010 seems to be a temp sensor in the transmission. Please correct me if I am wrong. Thanks.
Here's what I got:
TVV - 25820-13020
One is made by nippondenso. The other is made by some other company. both were the same price if I remember correctly. I selected the denso
I looked again. you are correct. I was confusing it with the temp gauge sensor found here.
