SOLD 1997 LX450 - Texas (1 Viewer)
Year
1997
  1. LX450
Mileage
203000
Outside Link
https://photos.app.goo.gl/bfuKKdteZhMZZooF6
Bringatrailer auction went live today!!
This LX450 is showroom quality.
I just submitted it to BaT (Bringatrailer.com), but I'm also open to selling it to a MUD member since I have heard it takes BaT a while to process new submissions.
203k miles currently, and sitting in my garage. Asking $32k.
TONS of photos here (around 250 photos): LX450 - https://photos.app.goo.gl/bfuKKdteZhMZZooF6
I have talked to a few of you that are interested over the last 24 hours, and thought a video walk through would help answer a lot of questions. Below is a video walk through I just did. Please let me know if you have any questions, and feel free to call me as well:
Following have been done in the last 2 months by me:
* All 3 belts replaced with OEM toyota belts
* OEM Denso iridium spark plugs
* OEM Toyota distributor cap and rotor
* OEM Toyota spark plug wires and coil wire
* Power antenna
* Trunk hatch gas struts
* Hood gas struts
* OEM Toyota PCV valve
* OEM Toyota valve cover & PCV hoses
* Oil and filter change
Following were done by the previous owner in the last year or so:
* ARB Front bumper
* Black Rhino wheels and CNC machined spacers
* Procomp AT Sport LT285/75/16 tires
Following were done by the previous previous owner here on MUD around 2018-2020:
* Valve cover gasket
* EGR components
* Radiator
* Throttle cable
* Front birfields / knuckles rebuilt and resealed
* PHH - Gates green stripe, with breeze constant torque clamps
* Radiator hoses and breeze constant torque clamps
* Fan clutch
* Exhaust - OEM style
* Full interior carpet replaced
* Full leather replacement along with center console lid and doors
* New hood insulation
* Old Man Emu front and rear coil springs
* OEM Toyota shocks
* EBC brakes
* Full glass and trim out re-paint
* Replaced all side glass (doors)
* Replaced third row sliding glass with new OEM Toyota solid single piece glass
* Pioneer door speakers, retained factory door panels and speaker grills
* Replacement 4" sub in center console
Everything works and functions as it should. No leaks. No rust. No check engine lights. No problems at all. It's about as perfect as an 80 series gets.
I'm located in Round Rock, Texas (just north of Austin). Happy to answer any questions and have you swing by to see it if you're interested.
A few more photos. See link in the first post for Google Photos link with around 250 detailed photos.
Yep, green; tons of photos in the link. I know lots hate on the green but I think it's a unique color and it shifts with the light to where it looks black and blue. It's a sweet color imho.
What color is it? Green?
It is the factory lexus color for the year called "Dark Emerald Pearl". It was a two tone color with a pearl/metallic gray at the bottom half and fender flares. The color code for Lexus Dark Emerald Pearl is "6M1", I think. One of my favorite colors on the 80 series. Looks almost black at night, and very deep dark metallic/pearl green in the day.
A couple people asked for a cold start video. Finally got home from work early enough to take one today. Here ya'll go.
All following preventative maintenance done over the last few weeks. None of it was really needed, but I'm just a weird guy that doesn't like leaving anything untouched. I'll upload videos of all the work soon too.
Iridium spark plugs
PCV Valve and hoses
New Duracell Group 27f battery
Heater control valve
Radiator
Thermostat and gaskets
All 3 drive belts
Spark plug wires
Distributor cap and rotor
Distributor o-ring
Ignition timing set to factory setting of 3degrees
Video walk through of temperature readings at normal operating temperature of the radiator inlet and outlets, temperature of the cylinder head, temperature of the exhaust manifolds, temperature of the AC vents with heater on, and temperature of the AC vents with cooling on. Also included in the video is hands-off driving to show the how the LX450 tracks straight under acceleration, coasting, and braking.
Uploaded a lot more videos of the recent maintenance in detail, walk throughs of different functions, condition, etc.... Keeping them all in this running playlist that I'm adding to:
LX450 Playlist on Youtube
Dude this thing is ****ing beautiful. I'm not sure a BaT buyer would care about hood struts or hatch struts but you have the info so why not? I don't think you'll have any issue on BaT getting top dollar. You'll take a hit for it being a Lexus vs Toyota but nothing you can do about that. I'm really excited for this thing to go live; you have my support!
Been collecting as much history as I could about the vehicle from sources available and consolidating into a single spreadsheet.
9/27/97Manufactured and shipped to dealerFrom carfax
10/1/97Install tow hitch. Lexus dealership10From Lexus records
10/1/97Install running boards. Lexus dealership10From Lexus records
11/1/971000 mile service. Check tires, belts, fluids, electrical, wiring, road test, lubricate chassis. Lexus dealership1303From Lexus records
12/15/97Titled to first owner10From carfax
1/1/98Check phone roaming. Reprogram. Lexus dealership3883From Lexus records
6/11/98Title or registration issued or renewedFrom carfax
10/1/98Grease all fittings. Check hinges. Hose condition. Tires front 7/32, rear 6/32. Oil/filter change. Check and tighten all bolts. Inspect and correct belt tension. Check vibration, balance tires. Wash. Inspect battery and terminals. Replace air filter. Replace windshield wipers. Inspect suspension. Remove and replace 1 shock. Lexus dealership.12976From Lexus records
2/1/99Inspect brakes, need to be replaced. Adjust rear seats. Grease all fittings, hinges, hose condition, wires. Check tires. Leak from oil filter, replaced oil filter. Phone cord adjusted. Oil/filter change. Correct belt tension. Clean battery terminals. Replace windshield wipers. Lexus dealership21195From Lexus records
5/11/00Passed emissions test36712From carfax
7/1/00Inspect brakes. AC too cold, trained client. Oil/filter change. Check wire and hoses. Flushed cooling system. Clean battery terminals. Replaced 6 spark plugs. Replaced and flushed brake fluid. Replace windshield wipers. Correct belt tension. Replace air filter. Replace transmission fluid. Replace differential fluids. Lexus dealership.38943From Lexus records
4/19/01Passed emissions test46221From carfax
1/11/02Title or registration issued or renewed53814From carfax
1/15/02Fix wires on trailer plug. Inspect ball joints, bolts, chassis, brake lines, pipes, hoses. Replaced rear brake pads and rotors. Oil/filter change. 4 wheel alignment. Replace air filter. Resurface front rotors. Replace front brake pads. Lexus dealership53985From Lexus records
2/1/02Crankshaft oil seal, remove and replace rear crankshaft seal (rear main seal). Replaced crank bolt. Lexus dealership.53998From Lexus records
10/1/02Replace antenna assembly. Replaced rear brake pads and rotors. Oil and filter change. Replace front brake pads and rotors. Check 4wd, hard to go into 4LO. Fixed. Lexus dealership60991From Lexus records
3/1/03Remove and replace starter. Lexus dealershiop64195From Lexus records
5/1/03Oil and filter change. Clean belts. Lexus dealership66038From Lexus records
5/6/03Vehicle serviced66038From carfax
10/3/03Title or registration issued or renewed67819From carfax
10/15/03Program 2 key fobs. Lexus dealership68976From Lexus records
3/4/04Passed emissions testFrom carfax
3/10/04Title or registration issued or renewed68065From carfax
4/4/05Passed emissions test78000From carfax
3/24/06Passed emissions test82000From carfax
12/1/06Service complete. Lexus dealership.84699From Lexus records
12/29/06Passed emissions test85019From carfax
3/27/07Title or registration issued or renewed85500From carfax
1/22/08Passed emissions test91000From carfax
12/31/08Passed emissions test93000From carfax
1/15/10Passed emissions test97000From carfax
5/10/10Passed emissions test99000From carfax
4/25/11Passed emissions test115000From carfax
5/18/12Passed emissions test135000From carfax
7/9/12Vehicle serviced at Roberts Toyota. Maintenance inspection. Oil and filter changed137286From carfax
5/31/13Passed emissions test153000From carfax
1/14/14Passed emissions test163000From carfax
12/22/14Passed emissions test167000From carfax
2/21/17Passed emissions test172000From carfax
2/12/18Passed emissions test176000From carfax
2018-2020Front axle, knuckles, birfields, and seals rebult170-180k milesFrom IH8MUD owner
Front shocks replaced with new OEM Toyota170-180k milesFrom IH8MUD owner
Rear shocks replaced with new OEM Toyota170-180k milesFrom IH8MUD owner
Valve cover gaskets170-180k milesFrom IH8MUD owner
New EGR sensors and components170-180k milesFrom IH8MUD owner
New radiator170-180k milesFrom IH8MUD owner
New engine fan clutch170-180k milesFrom IH8MUD owner
New throttle cable170-180k milesFrom IH8MUD owner
New PHH - Upgraded gates green stripe hoses170-180k milesFrom IH8MUD owner
New radiator and coolant hoses170-180k milesFrom IH8MUD owner
Breeze constant torque clamps for cooling system170-180k milesFrom IH8MUD owner
New heater control valve170-180k milesFrom IH8MUD owner
Complete new exhaust with cats170-180k milesFrom IH8MUD owner
New carpet for entire truck. With new sound deadening foam170-180k milesFrom IH8MUD owner
All new leather custom built and installed by Roadwire170-180k milesFrom IH8MUD owner
New OEM Lexus seat foam170-180k milesFrom IH8MUD owner
New hood insulation170-180k milesFrom IH8MUD owner
Old Man Emu coil springs170-180k milesFrom IH8MUD owner
EBC Brake upgrade170-180k milesFrom IH8MUD owner
Pioneer door speakers170-180k milesFrom IH8MUD owner
Replaced 4inch "sub" in console170-180k milesFrom IH8MUD owner
All drivetrain fluids changed170-180k milesFrom IH8MUD owner
Replaced some of the hard brake lines170-180k milesFrom IH8MUD owner
New OEM Toyota extended brake lines170-180k milesFrom IH8MUD owner
All new glass ordered from Toyota overseas. Third row sliding glass replaced with single piece Toyota glass.170-180k milesFrom IH8MUD owner
All new window trim and gaskets170-180k milesFrom IH8MUD owner
New weatherstripping170-180k milesFrom IH8MUD owner
New rain gutter trim170-180k milesFrom IH8MUD owner
Full trim out and glass out professional repaint and restoration of entire vehicle170-180k milesFrom IH8MUD owner
4/11/19Passed emissions test177000From carfax
In 2020ARB Front BumperLast owner
9/9/21Vehlcle sold to me202433From carfax
In 2022New OEM Toyota Distributor cap, rotor, and oil seal203k milesCurrent owner "me"
New OEM Toyota spark plug wires203k milesCurrent owner "me"
New OEM Toyota Denso Iridium spark plugs203k milesCurrent owner "me"
New OEM Toytoa PCV valve, grommet, and two hoses. With new OEM Toyota clamps203k milesCurrent owner "me"
New OEM Toytoa Center differential lock switch installed203k milesCurrent owner "me"
Compression test, cold dry test, all cylinders between 175-180psi cold203k milesCurrent owner "me"
Set base ignition timing to factory 3 degrees203k milesCurrent owner "me"
Replaced radiator with a new one203k milesCurrent owner "me"
New OEM Toyota heater control valve203k milesCurrent owner "me"
New OEM Toyota drive belts. All 3 belts replaced203k milesCurrent owner "me"
New Duracell 27F high capacity automotive battery203k milesCurrent owner "me"
New hood gas struts203k milesCurrent owner "me"
New trunk hatch gas struts203k milesCurrent owner "me"
Power seat gears removed and replaced203k milesCurrent owner "me"
Oil and filter change203k milesCurrent owner "me"
New OEM Toyota air filter203k milesCurrent owner "me"
New OEM Toyota red coolant203k milesCurrent owner "me"
New OEM Toyota thermostat and gaskets203k milesCurrent owner "me"
New OEM Toyota radiator cap203k milesCurrent owner "me"
The BaT auction ends tomorrow!!! Very curious to see where it ends up and who the new owner will be.
So..... What do you do when the winning bidder calls you very shortly after the auction ends to tell you a BS family excuse about why he can't follow through with the purchase?
Anyone want this beauty? I'm exhausted with this process.
Man that sucks. Did bat give you the contact info for the second highest bidder? Seems like they’ll be pretty close to the winning bid accounting for the buyers fee that they now no longer have to pay.
Not yet. I sent BaT an email last night. Waiting on a response.
