Out of the blue, one day it would crank, but not start
No Check Engine Light with ignition key turned
Checked voltage through all fusable links: All good
Checked all fuses: All good
Checked voltage in under hood fuse box: All good
Replaced EFI relay
Checked voltage on interior OBD2 and under hood test port: All good
No spark
No voltage on coil power supply wires.
I did a quick inspection on the wires near the EGR and they seem ok.
I'm about test and inspect the ECM wiring.
What's the most likely cause?
I'd appreciate any ideas, so I can check those first.
Replaced EFI relay
No spark
