Builds 1993 80, BUILD, another "it has begun" for fjbj40! (1 Viewer)
What are you using for the insulation material on the bus bar?
West epoxy with milled fibers. The “box” is laminated E glass cloth and carbon fibre.
Wow, that sounds like a whole new skillset is required 🤣
Not super difficult, just practice, it’s part of my professional skill set as an aircraft mechanic/structural repair tech.
Winch power finished
Getting there
Clean work !
Very nice !
More details…
Did not want a constant hot feeding the winch for safety reasons. Luckily I have the OEM main “magnet” that I control with a switch and added a power indication lamp powered by the output side.
Switch and lamp courtesy of aircraft recycling 🍻
I dislike zip ties so I control wires by lacing cord, same as in aviation applications.
One thing I must say is there is not a lot of real estate in the 80’s engine bay!
Added a switched buss bar. Used fuse tap on charge 7.5 amp fuse. A 5 amp fuse feeds the buss, it’s only for relay activation.
There is a empty spot in the fuse box that can use a 95220-21000 (20 amp) relay. Female spades need to be added but it’s doable. I thought about it as I have all necessary parts but didn’t feel like doing it.
