- Thread starter
- #161
I cant praise these stainless trays enough they are awesome! Passenger side tray installed.
I sprayed the A pipe welds and flanges with some cold galvanizing compound for corrosion protection. Only made another two foot section of the exhaust last night so not much to show there. Im going to go ahead and driver it in to where I work and do some more exhaust fitting with it on a lift and also need to run my bends over to the local muffler shop so they can swell them all on one end.
I fired it up last night and it immediately shut off. SO I check the shutter diaphragm and sure enough its closed! The shutter vsv is open in its normal state (at rest) It needs 12v applied to close and the shutter to remain open for the engine to run. Which is much simpler than what I had initially thought that it needed 12v to shut the engine down. So all be pulling that rocker switch of the dash or at least repurposing it and simply make a 2 foot long harness to run from the shutter vsv to an existing ignition on 12v plug on the driver fender that used to run to the carb. Easy peazy!
Oh and my denso compressor arrived today so i'll be putting it on this evening and driving it home. Need to get one more fitting fixed on my hoses and I can charge the a/c up.
