- Thread starter
- #21
pretty clean look. open the single door, flick a switch and your away.
A rough mock up of where the barrel will sit.
this is a 4'' x 10'' barrel.
The engine moves SIGNIFICANTLY when under load/WOT. Driving with the hood off for the past 2 weeks has made it apparent why there is such space between the radiator/fan shroud and the fan itself.
That said, interesting placement of the barrel. Good luck!
Had to redo some paint after I've installed the antenna and 4 pin bulkhead fitting. Plan to use it for camp lights, light bar and solar panel on the roof cage with common earth.
Looks on the piss, but the radiator is just sitting there while I bolted down the intercoolers heat exchanger. Made up a bracket that picks up on the m8 nuts inside the chassis rails- that holds the power steering cooling tubes.
Painted all the brackets and fan shroud. All fits well. Just waiting on some Al pipe and I'll have her on the road for a test.
