Started my trip by a visit to Grenoble, then a few days in the Alps at friends house.
Then headed to the Jura for the 40 series meetup.
Of course I never succeeded to capture every participants... Always someone taking the aperitif somewhere x)
And during a roadbook through the wood I succeeded in getting stuck in a mudpit... The 4 leaf springs stuck on the center ground.
Which gave me the opportunity to use my PTO winch to pull myself out for the very first time!
(tree protector and pulley were used)
Was afraid of breaking the pin but the winch did an easy job of pulling the FJ40 sideway to get back the left wheels on firmer ground.
Not sure, it's an Instagram suggestion searching for Land Cruiser.Where can I find the Land Cruiser song from your Instagram video?
If the springs are in there correct position front ones on the front rear springs on the rear. Not mixed up. The simplest solution I see is using slightly longer shackles.In the mean time I want to submit to your opinion an issue I got with the suspension. It's not related to this trip but I discovered the issue during this trip while parked in cross axle. And this issue happened a lot during this trip because of the nature of the terrain and how hard it is on suspension.
The rear leaves bushing eyes are contacting the frame before the axle reaches the bump stop.
This leads to not using the extra charge leaves and when loaded I'm very often hitting in the rear... And as you can see not hitting the bump stop but the chassis...
Front does not have this issue and cnz reach the bump stops.
By the end of the trip my rear hangers took quite a hit... And I can tell you hearing that many bang in the rear wasn't pleasant.
The suspension is OME, as far as I know the shackles are original.
My theory is that OME has only 1 model of leaves for pre and post 1980 40series with the big eye of the post 1980 (and compensating with a bigger bushing for pre 1980), so this bigger eye than original is the reason it's contacting the hanger before the bump stop.
But it's only a theory, maybe I'm missing something here?
I tried to search but didn't find any mention of this issue previously? Is it a known issue? How could it be fixed?
If this is really the issue this is a big oversight from ARB/OME on this one...
What you are experiencing is normal, given that any spring which offers lift consists of blades that are longer than standard ones. When fully compressed, what you experienced is the effect.In the mean time I want to submit to your opinion an issue I got with the suspension. It's not related to this trip but I discovered the issue during this trip while parked in cross axle. And this issue happened a lot during this trip because of the nature of the terrain and how hard it is on suspension.
