Builds 1965 FJ45lv build up/resto thread (17 Viewers)
Everything looks like it's coming together well. That setup will definitely make you happy when its all together
Hope everyone had a merry x-mas.... :) Just got back this evening from the wifes parents place, figured I would do a little work. Also got to drive the 40 about 400 miles in less than a 24 hour period, I love road trips in that thing :D
Got home tonight and figured I would get the tranny hump cut out for the shift levers. Made some marks and started cutting. Had to put it back on and off about a dozen times, but got it where I wanted it. Then I placed the rings over the top and drilled all the holes for the screws and installed them. The T-case ring I had to put in the vice and heat with the torch and slowly bend the aluminum to contour to the hump itself. Turned out pretty good.
I then spent a few hours and stripped down the T case lever again, took it down to every piece. Also stripped down the drivers side seat to every part. Plan is to get up in the morning and start sandblasting, have quite a few parts, probably take a couple hours and then start shooting epoxy primer and paint later in the morning.
Might have some people coming up next weekend to do some sewing, seat pans and tracks need to be ready ;p
Matt
last 3, I take pics of some stuff before I take it apart. I was taking pics of the seat parts and my helper was helping out.
Figured I would post a pic of him, he likes to get into the action any chance he gets ;p
Matt
Good thing that's the old upholstry....:eek:
Looks like them claws are working....
Took the day off today, so got some quality LV time in today. I might have a sewing team showing up this weekend so I needed to get my seat metal ready to go. So started off the day sandblasting.
Blasted the front and rear seat pans, all the seat tracks, all brackets + I blasted all the T case linkage and some other misc. stuff. Once the seat hardware is out of the booth I'm going to hang the linkage and driveshafts and get those epoxy primed and painted black. Painting went real good except for one of the seat pan brackets had a crack in it :frown: I can't believe I didn't see that before or at least when I was priming :rolleyes: I had just started shooting the first coat on that pan and saw that. So I didn't spray any more color on that pan, but finished up everything else. Let it dry over night and fix it tomorrow. Try to get it primed again and sprayed tomorrow.
I then went to work on the seat belts. Doesn't look like much, but it took a while. The pics pretty much explain it all. I decided to thread the front seat belt attachment point into the side of the seat frame, that seemed to work well and Poser thought of that one when he was up here.....good idea dude. ;) I made plates for the rewind mech. 1/8" x 1 1/2" x 6" and then welded a 7/16 nut onto the plate. I drilled holes through the floor and spot welded it into place. Essentially sits directly on a rib underneath, the same width as the rib. When the body comes back off, all that will be seamed sealed around it, primed and painted. In the event of an accident, the rewind mech would have to pull that plate through the floor...I don't see that happening. I made L brackets to hold the rewind mech. I welded a nut on the back side and had to drill a hole for the alignment pin. I then had to cut a hole in that triangle piece to relief it for the nut and alignment pin on the back side of the L bracket. Drilled a hole in the bottom of the L bracket and good to go......I guess I don't see it pulling out anywhere???
The L bracket will be painted in contiental beige. You actually won't see it since the carpet is going to go over the top of it also.
Matt
more
more2
more3
more4
more5
last one of the belts
What do you think, fuse block in this area underneath the wiper motor??
Read the thread every 3or 4 weeks. Let me add to the others. Graet work, great thread.
I noticed some NOS 45/55 side mirrors on ebay now...item # 8024574800. Not mine, just saw you were looking for some last week.
If anyone hasn't sent you dimensions of the 62 console, I can do tomorrow when there is some light outside.
Mike
Mike
Saw the mirrors, thanks. I actually got a set coming from Cruiser dan last week, along with a couple other things. :)
Got the dimensions and some pics off the 60 series forum after I posted a thread asking for pics and dimensions last week. I actually have a console coming out of a 89 from another mud member. I don't think that I'm going to use the console itself, but I think I am going to use the guts out of it and make my own center console.
Thanks, Matt
Thanks, Matt
Glad to hear that; I didn't think the plasticy look would go well in what you are creating...
I noticed that crack in the picture of your cat. Thought about posting to ask if you were going to beef up that upper seat bracket since they always crack there (weak point of those era seats). Guess I should have posted. Seatbelts look great, as always top notch work.
Yea, I saw the crack weeks ago and had plans on fixing it. Sandblasted it, primed it and never saw it until paint? I'm loosing it, I know that now........:confused:
Got busy last night, so nothing got done. I plan on fixing that seat pan tonight and get it painted. I also plan on priming and painting all that other stuff black tonight.
Thanks on the seat belts, I think they will work well. When I do the final assembly the belts themselves are going to get dye'd black again so they should look new. Also plan on painting the plastic on the rewind mech with a paint or dye designed for plastic continetal beige so it should match the interior.
Matt
Nice work on the center shifter area. It's really looking good
