FJBen
WARNING, multiple conference call math and attention span.
So when I rebuilt my 13BT ~2 years ago, I just had the stock turbo rebuilt. In hindsight, I should have researched more and got an upgraded turbo as the CT26 they put on the 13BT is sized wrong from the factory. I've read countless threads over and over and think I have a fairly good idea of a few turbos that would work, but just want to run it by those much smarter than me on turbos.
Currently has a rebuilt CT26 with about 20K miles on it. Works good, just too big and a little lazy for the 13BT.
13BT, 3.4L, 120HP stock, 200ish for torque (I think wikipedia is wrong...shocker, on 13BT torque)
120hp @ 3400rpm
200tq @ 2000rpm
"IF" I did my math right according to the internet (I'm sure it's probably wrong)
13BT, 3400cc = ~208 cubic inches.
208ci x 3400rpm divided by 3,456 = 205
205 x .80 efficiency = 164cfm (is my efficiency too low?)
2:1 that would be 327cfm at 14.7psi
3:1 would be 492cfm at 29.2psi
I won't be running 30psi, ideally topping around 20ish, so that would be 410cfm at 22psi, If I'm correct.
Now further down the bad math hole I go, if I'm converting cfm to lb/min I've seen multiple ways to do this, or people saying it's impossible, weather/humidity/air/earths wobble at axis etc..
410cfm / 14.7 = 28lb/min (no idea if this is right.) or 410cfm * .069 = 28.29. So somewhere in there...
So needs 410cfm, or 27~28lb/min and around 2.5pressure ratio
So if thats somewhat correct, here are some findings from mud and suggestions I've read. I tried to map them, so hopefully.
Garret GT2252R, seems to be a good fit
GT2052 - might be on the small side
As @Dougal has suggested the TD04H-19T. This looks like a pretty good fit for the 13BT, better than the GT2252.
The GT2052 has been mentioned, but I think it's a little small. Will boost away off idle but choke out pretty quick. Any other turbos of value I should be checking with?
@saltycoconuts how is your turbo swap going?
120hp @ 3400rpm
200tq @ 2000rpm
| Turbo PN | CHRA | Inducer | Exducer | Trim | A/R | Inducer | Exducer | Trim | A/R |
| Turbo Reference Data | Compressor | Turbine | |||||||
| 452187-5006S | 451298-0006 | 40mm | 52mm | 60 | 0.51 | 50mm | 43mm | 72 | 0.67 |
| 727264-5001S | 451298-0043 | 38mm | 52mm | 52 | 0.51 | 47mm | 40mm | 72 | 0.50 |
