bjowett
Supporting Vendor
Axles are approximately 2" longer. The 100 knuckle is likely forged, so it is strong and easy to weld to.
What if you don't want to go full long travel, but would love the performance gains of a coilover front end versus the TB? Could you fit a set of those upper buckets in the photo, throw some upper arms, and maybe gain 2" of travel keeping the stock CV's happy? I would love to stuff a set of ICONs up front and ditch the bouncy OME shocks and Torsions.
That's basically what this kit is. They are calling it "long travel" but they haven't extended the CV axles, the lowers are basically accomplishing the same kinematics as the OEM lowers (Longer lowers would increase track and require longer axles, which they have confirmed is not the case)... so in my eyes, this kit is only "long travel" in name, not in function... which is a bummer
You would essentially be gaining some travel I would assume, maybe not incredible long travel numbers but an increase over factory. What are they selling this kit for? It looks like a game changer for the 100 crews who are pretty much locked into OME torsion bars for most setups. Has it been tested on a real world rig yet? I would love to hear about performance gains on and off road.
100 Series Coil Over Conversion KitWhat if you don't want to go full long travel, but would love the performance gains of a coilover front end versus the TB? Could you fit a set of those upper buckets in the photo, throw some upper arms, and maybe gain 2" of travel keeping the stock CV's happy? I would love to stuff a set of ICONs up front and ditch the bouncy OME shocks and Torsions.
I believe something like that would far exceed the average persons budget when it comes to building their truck. It looks very cool and functional, and I’d love to see how the suspension cycles. But that setup is being run on a $150k+ trophy truck...I’m sure that entire suspension system would cost more than the resale value of any 100 Series.I had come across this style of UCA that I had never seen before. What is the disadvantage to it? Why don’t more designs use it?
This kind of UCA is utilizing a heim joint in the lateral position set up in a double shear configuration. Super strong and the heim joint being in that orientation removes the heim as a limiter of travel. However, with the joint in that rotation your steering angle suffers, so does the steering performance. So it’s not really good for anything but a fast desert prerunner. Also it requires a completely custom spindle (the heim joint actually sits in the spindle) so basically you only see this configuration in one-off front ends.I had come across this style of UCA that I had never seen before. What is the disadvantage to it? Why don’t more designs use it?
