100 Series General Tech and Classifieds (3 Viewers)
Came home from California and am now in need of a white tailgate for a 1999......
What is looks like behind you speaker grille cloth. The past few years have been rough on the cloth so ripped it off.
Then got around to painting the grilles.
Grey is the color under the tan cloth.
Same place I did a usb Install.
What are you powering that uses cig plugs? I'm with fireman, mo USB power. I added one of these to the center console up front so all our i-Devices got power now. It got wired to my Blue Sea fuse box that has key off power. Keeps the GPS powered when the trucks not running.
Those were USB power ports he installed. Just happen to be round.
DENSO 210-0281 Reman Alternator for 100 series. Brand New. You will have to reuse the plastic piece around the output terminal as this one arrived damaged. Was going to keep as a spare but have decided to sell instead. $85
I had a VSC light staying on after switching off the Center lock, I had to shut off the truck and restart it to make it go out.. seemed like a sensor so when I got home I did some digging and found it was probably the sensor on the tcase hanging. Dealer pricing was upwards of $60 but I found a post with some alternate part numbers, so $14.00 and a little time had it fixed. Just wanna pass it along In case anyone has this issue.. apparently it’s fairly common on 80’s and 100’s Here’s a couple threads on it.Replacement for 84222-12010 switchCDL Sensor/SwitchCDL Sensor/SwitchCenter Diff Light Fix - My Experience
I’ll just pretend the broken plastic piece is worth the $115 extra that I paid for mine. :bang:
