- Joined
- Oct 24, 2014
- Threads
- 28
- Messages
- 324
Wish I had the time to do a proper build thread but instead I will aggregate all of my past posts and do the best I can for future additions.
Most of my 03 LX470 is stock. The only "mods" for better off-road performance has been removing the running boards, and adding good AT tires. This is our primary vehicle for North American travel, we use rental or friends' vehicles in other continents. Typically we find that it is 95% or more pavement travel, due to how developed the US and Canada are. So I've focused more on interior organization and comfort for living out of the vehicle for a week to 2 weeks at a time.
One of the very first things I felt would make my family comfortable with the idea of overland travel was a fridge. My fridge build is documented here: Edgestar Fridge Modifications Thread - https://expeditionportal.com/forum/threads/edgestar-fridge-modifications-thread.47802/page-14#post-1949532
Almost any modification is a slippery slope, and soon I found the OEM battery and wiring to be inadequate in supporting the fridge. Some 8ga cable and and Anderson SB plug later, the problem of the fridge shutting down due to "low voltage" (it wasnt really low voltage at the battery but rather a large voltage drop across the OEM wiring) was fixed.
I upgraded to a single AGM battery soon after: Battery size 49 - will it fit? Also bought a 50W solar panel and wiring which get stowed and deployed as necessary.More details about the solar setup here: Minimalist approach - OEM battery + solar? I have found this setup to work for about 2 nights of camping at a time without any issues. If we stay longer than that in one spot, it is almost always at a developed campground with shore power. As a foolproof backup, I carry a Antigravity Microstart XP10 (which I also take without exception on all international trips - it gets a lot of attention through airport security
The next step was communications, and at the time we felt CB was a good option to go with (a terrible decision!). I removed the CD changer and decided to hard-wire a radio in its place.
The stock CD changer bracketry adapted for the Uniden PRO 520 XL radio, the tan colored stuff is a piece of modeling foam which supports a trim plate:
How it sits inside the center console, at the bottom left you can see the external speaker for the radio recessed into the carpet.
The final install. There are absolutely no exposed cables in the cab. In hindsight, the whole CB experience has been less than satisfactory despite carefully tuning SWR etc. Thinking of switching to GMRS at this point.
