OK Kids, Gather round. I have a real puzzler for y'all.
Did an oil change tonight on Zippo, the truck that bursts into flames - 86 BJ70 w/ 599,010 kms. Truck idles outside the shop for a few minutes while I park all the rigs back in the spots, and take off. As I pull onto the main road, the EDIC starts doing the 'Funky Chicken'. That, as you all well know, is when the Fuel Control Relay sends repeated signals to the EDIC motor to overinject-run-off-repeat.
It does this at about one cylce per second all the way down the road. I pull over and detach the EDIC motor arm from the fuel control lever so as to prevent further instances of my head smashing into the steering wheel while trying to accelerate.
On the way home, I turn down the heater fan, and viola, the funky chicken slows down... overinject-run-off-run-wait 3 seconds-repeat. Wierd. I get home, turn off the headlights, and the funky chicken stops entirely. Wierder. OK, so I turn the running lights on, but the headlights off... funky every 5 seconds. Headlights off again, and it's fine. Fan on high, funnky every 3 seconds. Fan off, stops again. Headlights on and fan on high, it's constant.
So, the Fuel Control relay is going beserk with the load on the electrical system. Any guesses as to why?
My guess is bad ground. I'll clean the terminals tomorrow and see if that helps. Any other ideas?
Peter Straub
Peter Straub
Unfortunately for me, my 24V '87 formerly FJ now HJ-60 is doing the dance
I am thinking the relay is bad through process of elimination. I am not sure how to test the relay to see if it is bad.
