- Joined
- Jun 29, 2007
- Threads
- 45
- Messages
- 1,539
Yes Rick! I had the batteries tested today.. one was weak so I replaced them both... then tested the output on the alt... not much to speak of : (
What was the measured alternator output with the new batteries? In my experience, you should be seeing 28-29v on a working system with good batteries. That's using a volt meter, not the gauge on the dash!
And importantly as Tapage suggests, what voltage are the regulator and EDIC relay seeing? Connections to these important functions should be verified.
Rick
guess I am going to probe some more wires
I ran jumper cable wires from the negative terminal on the battery to the block, EDIC motor, and relay to see if I could isolate a ground issue... no changes...
