Curtice
Creating this thread to document my FJ40 conversion to a 3FE. Also, since I have never worked anything close to this big on my cruiser before, I need a good place to ask all of my questions...there will be a lot, and many of them pretty basic probably. I have a good friend who has been very helpful so far (thanks Scott ), but I don't want to keep bugging him every day to answer every little question I have.
I also hope this thread will be helpful to other people doing a similar conversion who are rookies to this type of thing like I am. A lot of the information out there assumes a certain level of knowledge which I don't often have.
My biggest fear is putting everything together only to find out later I did something wrong and have to take major things apart. Just take it slow I guess.
I welcome all comments and tips on anything I am doing.
A little background. Its a 1980 FJ40 that I have had for about 12 years. It sat in a garage for most of that time, until I decided to revive it a while back. Did a bunch of body work paint job about 2 years ago. Also other work including new suspension, steering parts including mini-truck conversion.
Here is a picture after that work:
(I sold the hard top this summer and am awaiting a soft top.)
Late this last summer, had some engine problems. Not sure yet what happened, but I know its bad. Engine knocked all over the place, and now will not even start. So faced with the decision to rebuild or swap a new engine in, I got a line on a rebuilt 3FE. So decided to go that route. Once I am done with this project, I want to learn how to rebuild the 2F, so will work on that.
Here is where I am now. I have pulled the 2F and removed the bellhousing, flywheel, and clutch components to reuse with the 3FE. But I will likely purchase new clutch disc and plate while I have it apart. Also while I have things apart, dropped the transmission/tcase and in the process of cleaning up a bit. I also have all of the wiring pulled from the engine and behind the dash. As wiring is a huge part of this conversion, I am taking the opportunity to clean it all up, since things have always been sketchy.
While I have things apart, I plan to do the following side jobs:
Amaurer gauge upgrade
Clean and repair existing wiring that I will continue to use
New battery and starter cable
Clean and paint transmission, bellhousing, and skid plate
New clutch disc and plate
New parking brake cable (since my original is not in good shape)
Couple pics of the 2F removal:
As we were lifting it out, realized I wouldn't get the clearance to lift the engine over the frame because of the garage door. So had to set it one some 2x4's and adjust the chain shorter. It barely made it.
Cleaned up the engine bay a bit. Thought I might take this time to paint the firewall, but decided not to.
And cleaning the transmission/tcase. A lot of oven cleaner and washing. The oven cleaner didn't seem to hurt the aluminum, but I didn't leave it on very long. While it still looks dirty, it is 100x better than when I pulled it.
