What external fuel pump are folks running in a 3fe'd 40? Do you run a filter in line before the pump, then another after? Cross post
TIA
TIA
Here is my set up.
I run the mechanical pump on the 2F the 3FE can run one too it's just blocked off with a plate I believe.
The mechanical pump feeds a surge tank which my electric fuel pump runs from. This keeps the high pressure system to a minimum and also means off road less of a chance with regards to fuel pick up issues. You don't need to upgrade the lines to and from the tank either.
You don't need to go to quite the extent I have but the principal is sound with a more standard fuel pump and the stock regulators.
IH8MUD Forums - View Single Post - 2F + 3F-E = 2F-ETI Into My FJ40
, do you have the fuel pump cut-off wired in?This looks, do you have the fuel pump cut-off wired in?
Air flow meter what air flow meter![]()
TIA
Oh boy, I am going to have to dig into your build thread...
Do you adress your ECU connections in your build?
To answer the original post question, I am running the external pump found on the early EFI F-250.
I do not have current p/n or application.
I pre-filter the pump (you should see why! I'll post pics) and run a high press filter in the engine compartment from a Vortec. It has threaded connections, and is cheaper than the 3FE filter.
Do you have any pictures of your pump and plumbing?
Where is this picture from?
