Couple of members asked me to post up my conversion to a 3FE in my FJ40. I have more pictures that I will post when I figure out how to get a decent resize from a kodak disposable I used at the beginning.
I am starting with a little history, currently I am running the new wiring harness (Centek). Will update with progress as it occurs.
Hope this is helpful for everyone that is considering this conversion.
Parts:
1973 - FJ40
1976 - FJ40
1978 -FJ40
1988 - Fj62 -3FE Engine
New wiring harness - Centek
ECU
Main EFI Relay
EFI Relay
Mass Air Flow
Distributor
Coil/Ignitor
Front 3FE stock wiring loom
3FE stock down pipes
O2 Sensors - Bosch Universal
Little History -
78 FJ40 with custom rebuilt body
3FE Engine
I pull the body off the frame of the 78 and power washed and scraped getting it ready for a product called Chassis Saver. I did this as well on the 73 which was my original truck. However, I found the 78 and wanted the front disks and the Frame was in a lot better shape. So I sold the 73 and started over. Set back of 3 months.
Frame stripped
Parts:
1973 - FJ40
1976 - FJ40
1978 -FJ40
ECU
Main EFI Relay
EFI Relay
Mass Air Flow
Distributor
Coil/Ignitor
Little History -
3FE Engine
Frame stripped
