got my Delta vehicle systems panhard arm (rear) lift bracket installed. Had a shop install some extended front brake lines (my articulation was such that my brake line mounting tabs bent and I'm lucky I didn't hurt my old lines).
next up:
1) wrapping my exhaust with Ti/thermal wrap, the aluminium tub can get hot
2) re-fabricating my drivers front seat mount (lowering it by about 1.25" via cutting wheel, and re-welding it together)
3) using my new welder to fab up some rear mud flap hangers, will come off the frame with a spring joint at the mount point
How has that truck been running?
