- Thread starter
- #21
I know, right? This thing seems like it was babied. Pasadena truck for most of its life.Welcome! I can't believe how good your speaker cover looks with that mileage. Mine is thrashed...
Interesting, I don’t recall any white tab visible on either side of these, but these got reinstalled exactly as they had come out and didn’t have any issue with leaks, etc. before this project.Intake manifold gasket is installed, white tab up.
The wire housing blocks. Can be purchase from Toyota and easily replaced.
Cold weather slow crank, is not typically indication of a bad starter. Generally, it has more to do with low cranking AMPs. Like that of the group 24F and thick oil. Here in the Rockies, we like cranking AMPs of 27F batteries.
I understand that. What I’m saying is that for the last 20k+ miles this appears to have had the white tabs down, with no apparent negative results. So, I’m just curious if other people have experienced any sort of failure.White tabs up. Insure proper orientation of NEW intake gasket and sealing of when torque to spec..
