gregnash
Anal Retentive Analyst
Been running a 90915-YZZD3 toyota filter for my 98 since I purchased (changed oil about a week after she was home) and haven't had issues.. Amazon says that it fits a 2003 LC/LX so you should be just fine.
Not sure what the difference is, but the 2UZ-FE calls for the YZZD3. Since they use the same filters across multiple motors, I'm fairly confident that it won't work it it's a different part number.I have several YZZD1 filters sitting in the shelf …
These ok to use for the 2uzfe ??
Thanks for the info. Next change I’m gonna grab some d3 or equivalent filtersThere are two oil filter sizes that fit the North American 100-series V8 2UZ-FE engine. In Napa filter numbers, those are the 1348 (OEM and equivalent to YZZD3) and the 1516 (larger but fits and is equivalent to Wix 51516).
The Napa 1515 does not fit, even though I've seen it recommended elsewhere in forums. According to this parts website, the YZZD1 does not fit any Land Cruiser.
I buy either the filters in the first paragraph above or the Fram Tough Guard TG3614, depending on which is cheapest. I decided that as gentle as these engines are on oil and filters, the higher priced models below that are recommended elsewhere were not necessary:
- Mobile1 102 (oem size)
- Mobile1 209 (larger size that fits)
- Toyota OEM Japanese-made 20004
- K&N
