jstncse
Crawling over something
You will be fine!! Torque multiplication is you friend.
You are still running a 4l60, correct? If so it's plenty.
It's "new" (sat on a shelf for 5 years).Doesn't look like that thing was ever run.
I didn't think to look at timken (and never knew they had a search function on their site). Thanks for the info!I had to come up with a really odd-ball seal (because I didn't have a lathe) for my aw5/dana 300 transfer case adapter. https://www.timken.com/resources/
is your friend, they list the seals by size, but have a really good search function that allows you to spec out your seal. A quick google of the part number nets you the seal.
the problem I had was the OD of the area being sealed and the ID (shaft diameter) gave me about 1/4" difference with which to put a pressure seal (meaning it could hold pressure)....
