So I finally got around to getting this done,and it works.
I cut off all the bracket on the e brake except the 2 at the back end.
You will need the leave a 1/4 inch on the front top bracket or there will be clearance issues. I conected the rear bracket to the firewall as you can see in the picture finger pointing to the bolt. I routed the cable down through top the transfer case shifter rubber grommets there's 2.
