4Runner E brake
kdxman
Mesa AZ
So I finally got around to getting this done,and it works.
I cut off all the bracket on the e brake except the 2 at the back end.
You will need the leave a 1/4 inch on the front top bracket or there will be clearance issues. I conected the rear bracket to the firewall as you can see in the picture finger pointing to the bolt. I routed the cable down through top the transfer case shifter rubber grommets there's 2.
For the bottom I build my own bracket similar to the one used on the
4Runner 4 inch piece of angle iron that was attached with a longer bolt to the transfer case. Bracket attached to the angle iron is a quarter inch piece of Steel 7 inches long 1 inch wide at the short end why do the back end the holes I kind of just guess that seems to work okay pulse a little hard but it does work
not sure why it posted the fist pictures twice but, anyway.
and go for questions
Very nice! Thanks for posting up good pics. I see a connector/switch in there by the handle, do those hook up to our harness by any chance??
No the connectors are different
Thank you, sir.
you moved the handle (part that you pull) up higher than mine. That looks better as mine is too close to the edge
any photos of the routing of the cable that goes thru the floor and how exits
The level system you have underneath - that work ok?
any issues
Everything works okay pulls a little hard but not bad. I don't have any pictures from underneath the vehicle of where the cable comes through but I can take one if you want
So here are a couple pictures for underneath where the cable comes through
Not yet, I suck at electrical
yeah you're definitely not going to drive off of this thing on
1989 1990 1991 92 93 94 95 Toyota Pickup 4Runner Parking Emergency Brake Handle
1990-1995 OEM TOYOTA 4RUNNER PARKING BRAKE CABLE 46410-35650
so is that coming out on thru the steering rod location?
