5.74 grams per mile. Limit is 4. (used to be 9 when I first bought the truck). It's passed fine the last few tests. The only difference this year is that I retarded the timing. I had been having pinging and discovered the timing was set way too advanced. It probably had been that way since I had the headgasket done. Will advancing the timing reduce NOx emissions?
If not, does any know any standard cures for high NOx numbers?
