Just to throw out a few other possibilities: 1) Old vacuum lines tend to crack and leak at their connection points on the manifold. New rubber can be had from CDan and Beno on the cheap. 2) The EGR VSV is notorious for testing good when the engine is cold, but then failing after it heats up. This makes accurate testing a challenge. 3) The vacuum modulator is the "brains" of the EGR system, and basically functions as an analog computer. So look carefully at the PDF Pin_Head posted to understand how the system operates.
