So one of my Polk Audio DB651’s blew out a couple of months back,
Link to DB651’s
http://www.crutchfield.com/S-xxbdslj9seo/p_107DB651/Polk-Audio-db651.html
Luckily for Christmas Santa brought me some new speakers all around to replace them! The DB651’s sounded alright, definitely a huge upgrade from the stock setup, and along with the Scion 1809 radio the whole package sounded great for a while. That being said I was always looking for a little more bass and better sound all around, so for Christmas I got the Polk Audio DXI6500 Component speakers for the front and rear doors.
Link
http://www.crutchfield.com/p_107DXI6500/Polk-Audio-DXi6500.html?tp=106#details-tab
The install was pretty easy since I had previously installed the DB651’s. The front speakers require you to use the included spacers to make them fit. In order to make the rear speakers fit there is some trimming of the door frame is involved, as well as using the supplied spacer, as the stock speakers are only 5 ¼”, it can easily be done though with a Sawzall in a couple of minutes. The new woofers bolt right into the same locations that the previous speakers were installed, and the tweeters I mounted right next to the woofer and angled them up. The cross overs I mounted using double sided tape and some very shallow screws onto the door card. I trimmed the included wires to make them as short as possible to limit the excess wires possibly ending up creating a rattle between the door card and the door frame.
Compared to the DB651’s the sound output cannot be compared. The bass is very impressive for a budget component system, and the crossovers allow you to adjust the tweeters for optimal sound. I could finally turn up the volume on the speakers and listen to them LOUD to muffle some highway ambient noise the DB651’s always seemed like they couldn’t handle the power coming from the Scion 1809. Overall I am extremely pleased with the upgrade, not to mention the speaker covers look significantly better (the DB651’s were a little gaudy for my taste). I highly recommend them to anyone looking to get some better sound without having to add amp’s and sub woofers to their LC’s.
Thanks for looking!
P.S.
I’ll have some photos up later this week as the truck is currently in the shop having the valve cover gasket replaced.
Link to DB651’s
Link
Thanks for looking!
P.S.
