My plan was to remove the wind deflector and roof rack this weekend, as many on here have found rust under the towers or feet on these. My 80 that I purchased in Oct last year is essentially rust free, or so I thought. Last night I started to take the deflector off. The pics show what I found.
While I got 5 of the 6 screws out, one of the deflector nutserts (rivnuts) is spinning. My plan today, after searching here on MUD and elsewhere, is to try to tighten the tower back down in an attempt to clamp the nutsert. I may try a woodworking clamp on the tower to add extra pressure to the nutsert, as well as try to tighten the nutsert back up to the body (tightening the screw). If that does not do it, I will try to squeeze a scraper in there to hold the spinning nutsert from the side. After that I am planning to drill out the screw head inside the tower, then I will have better access. Some folks have then drilled out the nutsert.
Any other ideas????
As you can see from the pics, I will be attacking some rust. I am planning on welding the holes closed and repainting after repairing the rust, but I am still pondering this one.
In any case, considering some silicone sealers promote rust (the acetic acid issue), what are your specific sealer product recommendations for sealing a painted metal surface like the body with nutserts remaining.
The deflectors and roof racks were port-installed, correct?
The roof rack is next.
Thanks, Jon
Any other ideas????
Thanks, Jon
