Half of my brain wants me to go out and pull off my spoiler to check for rust, the other half says leave well enough alone.
IMO if removing and replacing the dust deflector it is important is to use a flexible thread sealant on the nutsert screw threads and on the top of the nutserts before the deflector is put back in place. I also removed and did not replace the thin foam pad that sits between the mounting bracket and sheet metal. IMHO for that location the foam pad appears to promote rust by absorbing water and holding it against the nutsert/sheetmetal connection at the lower nutsert.
I can sure appreciate that. Still, I gotta believe that with a properly thought-out installation, such as your write-up, the rust problems would be a long time in manifesting themselves. And I have thought that the one installed on my 100 does serve a purpose in that it seems to blow a lot of dust off the liftgate window, especially when I get back up on the highway heading home.
Thanks for your help.
