I've wanted a fuller set of rear quarter panels on my land cruiser for awhile. I am running smaller tires then the previous owner, and do not need the larger cutouts with the way I am wheeling right now.
But with this still being a trail truck, and far from a restoration rig I decided to make my own panels rather then buying them. I placed the order online at the local steel yard on Monday, and picked it up after work today. I hope to have them finished by the weekend.
Here is a before picture from the fall of 2006.
So after I cut the sheet in half, I clamped one piece onto the drivers side to mark out the rough cuts. After I decided where I wanted the cuts, I scribed some lines using a straight edge. You will also notice I scribed two sets of lines, the inner line is the cut line. The outter line is where I will be bending the lip.
Then I stacked both sides together, and clamped them onto my work surface (old picnic table benches) I used the sawzall to cut the longer straight lines, and a jigsaw to cut the corners, and a few shorter straight cuts.
Almost there...
And finished!
And clamped back in place, to see how it all looks.
Planning on cutting the old metal out on the drivers side tomorrow, and getting the new panel welded in.
Almost there...
And finished!
