Here is one that was installed in a fj60 with a 6.2 turbo diesel (I'll add, this was after the rear main seal dumped quarts and quarts of oil from high crank pressure)
thanks ntsqd...
i THINK we got it figured out...
we're going to run 1X2 inch square stock underneath the sides of the stock crossmember...
motor is on the hoist and bolted to the trans-t/c which is bolted to the rear crossmember...i think a one inch spacer is going to set everything in place...
I'M PUMPED!!!
I'm unclear here, are you spacing the stock end pieces off of the frame rails with the tube stock, or?
If you are spacing then you really want the tube sides to be parallel to the bolts (i.e. the bolts run down through the center of the tube). Unless the wall thickness is huge drilling through the sides of the tube will squash it when you tighten the bolts.
Same, btw, is true of the frame. I welded sleeves into the frame. I drilled an 8mm hole all of the way through, and then drill the outside holes, only, to 3/4" I made the sleeves from 3/4" bar stock. Bolted them in place, and then welded them to the outside frame wall only.
not that mine is perfect but it sits as tall as we could go and get the hood to close. My mounts sit on the frame a little different ...but we ended up cutting the drivers side mount off by "one hole" if that makes sense....My engine sits in there almost square. If you plan to ever run a mechanical fan its my estimation that you want the engine to be square with the radiator to the extent possible you can make that work. At first mine engine was offset a little (was jsut easy to do that. Then later went to a mechanical fan and "squared" up engine as best we could without doing major surgery. I initally ran dual electric fans from Ford v-6 contour...but have recently swithced to fan setup off a 1999 GM SUV/Pickup.
Here is a picture showing my frame and engine mount on one side and another showing the fan shroud I plan to adapt / test.
that shroud looks nearly perfect, what's that out of?
Updates?
