update!
well, "fluke" seems happy with her new heart...the motor and transmission seem like a perfect fit in the FJ62: power, size, set-up, etc....
the lokar shifter works & looks great! still need to install the boot.
i'm still having some T/V cable issues. it's mainly my fault in having installed a throttle body spacer which is throwing off the angle of the cable. that and the motor is from a GM Van with a funky throttle linkage...so i ordered one of these:
Bowtie Overdrives - View Item
i got my front driveshaft installed. i think it has enough clearance but without flexing the suspension i guess i won't know if it might knock the bottom of the 700R4...i'll try to get a pic posted.
i had the exhaust shop run 2 1/2" exhaust from the "y" pipe to a high flow cat to a Mangnaflow muffler...i kind of wish it was a little louder, but it's all good.
left to do:
-install the electric fan. (not in a big hurry since it's winter and i have the mechanical in there working just fine for the time being)
-install a tachometer interface to run the toyota tach...will post updates on this.
-i have two gauges to install: oil pressure (i think i fried the oem gauge) and tranny temperature.
-i should probably get a tranny cooler, but i'm waiting to see what the gauge shows...
-button up wiring in the engine compartment...does anyone have a recommendation on a fuse block or "power" center that i could run accessories off of from the engine compartment?
thanks for checking in! let me know if you have any comments or suggestions!
