ARCHIVE Wits' End Turbo Test Mule #3- no cartwheeling allowed (6 Viewers)
Huge thanks to for sending me a piece of unobtanium NOS 😳😳😳. I still need to figure out something to thank him 🤔
After the glovebox and some vents were removed, you can see where the mounting hardware is under the dash. From there it’s just making sure you don’t mess up 😳
I don’t always do things right the first time. I mess up all the time. But with each mess up I get a little bit better the next time.
The edge lifted on the left side juuuuust enough for the high temp white to spray UNDER the freaking template 😩
Got some repair work to do in the morning before I get lost in orders. 😞
View attachment 2411075View attachment 2411076
Does this mystery man have any more NOS? Asking for a friend.
Is that underhood insulation!
Ugh. I need to replace mine, but debating with myself about buying a new insulator only to cut it up (hood vents and scoop)
That looks great. I've heard gray you can still order, but i can't seem to located one anywhere to actually order.
Finally got the #York210 #OBA set up the way I wanted. Just took way longer than expected because so many other pieces needed to be in place first.
The York is of course belt driven but is turned on via a switch on the SwitchPro on the dash. It turns on the clutch which starts the action.
The plumbing goes from the factory air cleaner for clean/filtered air then is compressed and sent to the coelescing filter to have oil and condensation removed. From there it goes thru an unloader (check valve) and into the custom air manifold.
The manifold houses the liquid filled gauge along with the low pressure switch, safety valve, and then is sent out via an air coupler. Eventually it’ll go to an air tank but trying to decide where that should go first.
The cycling is the safety valve and cycling doing its job. If there is an air tank it wouldn’t cycle as often.
At idle it’s about the same CFM as an ARB twin. At about 2000rpm it’s at around 9.5CFM and will air up all four 35s in a few mins per tire 🤩
my daughter uses this handle constantly for tik tok videos during our trips, lol.......
This feels really good to do!
So far:
* JDM fan
* York OBA
* Power Inverter
* Methanol pump
All going thru the #SwitchPro and the Wits’ End Mount for it. Still trying to decide the other four switches 🤔
I'm telling ya, you need a party mode option :hillbilly:
Looks like a good place for a clamp-style tablet mount
Did a LOT of refreshing on the hood so I figured I'd do a separate thread:
Basically the end result...
On the methanol kit, I've got everything worked out but its not quite production ready because its not as bolt-on as I'd like it to be yet. Here is a simple mounting bracket solution for the boost switch. Its a simple hobb's switch. Its adjustable but I'll be setting them all here before they go out. Switch is normally off and once boost hits 2psi it connects to ground which turns on the pump. Let off the gas pedal and the throttle plate closes so no boost so the switch disconnects ground. Its crazy simple.
The issue was just about the mounting of the switch. A simple mount was made and it secures the switch to the unused bracket off the MAF. Works perfectly. I'll be making up a batch of these to go with the eventually kit.
Had a request from a customer to do an install for the WeBoost cell phone booster system. Since I’d never installed one before I figured I’d make the mistakes on my turbo truck first before I screw it up on a customer’s. Glad the turbo was the test mule. Spent way too much time trying to figure out a very clean install. Mounting it in the QPM was the best route.
The inboard antennae was routed to the front of the drawers and the outboard one was mounted to the back of the roof rack.
Special thanks to Dave Schenker and Delta Vehicle Systems for getting three systems out to me so quickly.
Only two things I’d recommend:
1) drilling more mounting holes for the plastic bracket is probably a better idea. I added four more.
2) don’t close the door/hood/hatch on the antenna cable before it’s properly routed 😞
View attachment 2420025View attachment 2420026View attachment 2420027View attachment 2420028View attachment 2420029
Since you mentioned the routing of the cable, how did you route this one?
